JMB RetrofitsVolks Autos
    Jan 2013
    57
    Jet black fuel filter and minor cold start issue
    Car is a3 2.0 tdi 170 bmn with dpf and egr removed..
    As above the fuel filter was jet black when I last changed it approx one month ago and the car has cold start issue..
    After the car sits for 6-8 hours it takes a couple of turns of the key to catch, runs rough for a few seconds then clears, somedays the cold start is worse than others
    Once the car is started its fine for the day and has no issues whilst driving..
    The car was checked by audi before my ownership for injector issues and according to my paperwork the injectors did not need replacing
    Read it could be tandem pump but at £200-£300 I want to know if it could be anything else before shelling out for a new one
    Torque, Torque, Torque
    Nov 2012
    147
    I have the same issue but on a 140 bdk. Mine is after it has sat over night, when I start it sometimes the engine shakes that much I think it is going to fall out! The revs jump to 1200 for a second then go back to 820. Turning the key on and off 3 times (not so it starts the engine) to prime the fuel seems to improve the start.
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    745
    Change the filter as a matter of precaution (about £15 for the part), they do go black after a long time & Im willing to guess its never been changed before, once you've done this get your car scanned on VCDS to check the torsion value.
    Ideally on the BKD you want the torsion value to be at 0.5, once this is checked & adjusted ok, manually adjust the rear cam to match the position of the front.
    The fuel filter & rough idle aren't necessarily related but they won't be helping your issue either, + its a fairly common guess to say the tandem pump is failing but without physically removing it you can't actually check the internal seals.
    Do a search for torsion value on this forum & it will bring up a shed load if info.
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted... Still....
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    939
    My fuel filter was jet black both when I replaced it around this time last year and this year. No cold start problem though. How old is your battery? Does the car smoke when you first start it from cold?
    VCDS USER
    Oct 2012
    139
    When my battery was failing the poor starting was actually quite similar to when my lift pump packed up about 6 months previous. In fact my first instinct was "oh no not again". New battery cleared the issue totally even though the old battery passed the test at the local autofactors. I put in a Varta Silver Dynamic and starting was like a different car.
    Apr 2013
    Kettering, Northamptonshire
    172
    Checked the glowplugs? I think each one should read 0.3 ohms
  1. black fuel filter
    By tdi-man in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th April 2011, 08:08
  2. Cold start issue
    By Connor_scotland in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th January 2011, 10:02
  3. cold start issue tdi 130
    By deanski in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th January 2011, 16:16
  4. Cold Start Issue......?
    By cliveywolves in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th February 2007, 14:48
  5. Cold start issues? Maybe it;s your O2 sensor.
    By eddyg in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st March 2006, 02:03
