Results 1 to 16 of 16
Like Tree2Likes
  • 1 Post By OVRA3
  • 1 Post By fangio
Thread: help!!
    Brodster's Avatar
    Shark Performance In Scotland
    Mar 2011
    Scottish Borders
    3,406
    Follow Brodster On Twitter Add Brodster on Facebook
    If they are coming on when the car is cold then no they shouldn't as they are controlled by temp sensor. If you've been driving then I would say yes they will be on..............due to the heat of the engine.
    Angelwax/BBS/BCS/Bilstein/Cobra/CTS Turbo/DTUK/H&R/K-Sport/KW/Loba/Milltek/Shark Performance/Oz Racing/TPI/VCDS/V-Maxx/Vossen/Wagner
    Apr 2013
    Aberdeenshire
    594
    Quote Originally Posted by stan 1 View Post
    even when the car is cold and i switch the heater on they are coming on is this a fault if so what will it be??
    as said before i no they come when aircon is switched on but aircon is of so take it theres a fault somewere??
    Is your coolant level ok i would advise you to get your car scanned if even just for peace of mind as you may have a dodgy temp sensor .
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,079
    My fans come on immediately when I take econ off.. It's normal we'll I assume its normal I have no fault codes!
    A3 Sportback 2.0 TFSI S-Line Quattro Stage 1 Tune it up - Lowestoft Custom Remap- 6187 RPM developing 260 bhp 279lbs ft Akoya Silver, Roof rails, Black heated Vienna Leather, Bose upgrade, Bluetooth
    Apr 2013
    Aberdeenshire
    594
    Quote Originally Posted by OVR70N View Post
    When econ is switched off that enables your a/c dependant on cabin temp and set point if the a/c is cycling to maintain your set point the fans will run however if you we're to put your heating up to full I would expect the fans to stop.
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,079
    Quote Originally Posted by Chillout View Post
    I don't think I've ever put the heating past 20 it's too hot lol! But yeah I'm sure they would as I said no fault codes so all must be well
    Mar 2011
    Cleveland
    992
    I think I read that one fan cools the compressor when the air-con's on.
    Mar 2011
    Cleveland
    992
    Who uses air-con constantly in Britain?
    Jack_tdi's Avatar
    Mar 2012
    Cumbria, England
    281
    Stop worrying lol
    If there's no fault codes and the fans are running I wouldn't be too bothered...... Better than them not coming on
    Mar 2011
    Cleveland
    992
    hi just wanting to no is it normal for the engine cooling fans to come on when i put my in car heater on??
    aircon is off
    Oops! Missed that!
    Sportback owner
    Apr 2007
    France
    496
    Stan, there is no logic in the fans coming on when the engine is cold, and the climate control is switched off. I suspect that one of your temperature sensors is not working to spec, and the engine thinks it's too hot. Get a VCDS scan as soon as possible and see what that indicates. Good luck.
    French A3 Sportback 2006, 2.0L 140 TDI, DSG, RSN-E, Ambient lighting, Auto-lights/wipers, Reverse assist, Dolphin Grey, 17" wheels, Leather seats, Cruise control, Roof bars.
    Apr 2013
    Aberdeenshire
    594
    hi Geraldy212 when you say climate control what do you mean as i dont have climate control i have econ auto and manual mode
    when on econ the fans will go off when on auto the fans will go on low speed when not on either they come on at fast speed and will stay like this untill i put it on econ??
    econ disables the a/c compressor as in economy less fuel used to run and will only use ambient air to cool the cabin
    while not on econ should your cabin require cooling it will use the a/c by running a/c your radiator fans will run to condense the discharge gas-to a liquid .
    Sportback owner
    Apr 2007
    France
    496
    Stan, when you first start the car, with econ = on, there should be no reason for the fans to start. If at any time you switch econ = off, then, depending on temperatures, the aircon (climate control) compressor will be active, and the fans may well start.
    Sportback owner
    Apr 2007
    France
    496
    Stan, with my A3, when econ= on, the fans are indeed off (when engine is cold)
    With econ = off, and 'Auto' =on, the fans will run fast or slow depending on the temperatures measured by
    the temperature sensors, and/or the cabin temperature settings. If the in-car temperature is high (on a hot day) and
    the temperature settings are around 20 deg C, the fans will run fast as one would expect. Hope this helps.
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,079
    This thread is hilarious... Its normal mate you are being paranoid!
    danb986 likes this.
    Jay.Ing's Avatar
    Jun 2008
    North West
    273
    It has been stated above by chill out, for those who dont know your air con has 2 heater matrixes one within the cabin (evaporator) to soak up the warm air (giving an illusion of cold air coming out of your vents), and one behind your radiator to discharge the hot air (Condensor). So when your air con is on (Econ not selected) and your not moving the matrix behind your radiator still needs to dissipate the heat it is dragging out of your cabin, so the fans will run, creating the airflow.
    Hope this helps!
    2012 A3 Ibis White SportBack Black Edition 140 - Going..
    Stuff for sale:
    Number plate LEDS
    Brand New Pipercross Panel Filter
    Light/Rain Sensor with Loom
    50mm H&R Suspension Kit
    Brand New H&R Springs (50MM)
    OEM Auto Dimming rearview Mirror
    Concert III with Aerial amps
    Red A4 Black Edition 150Tdi.... Arriving 29 July!!!
    Gone But Not Forgotten....
    2011 A1 Black Sline 106
    2006 A3 Red Sline 140
    Mar 2011
    Cleveland
    992
    Jay.Ing likes this.
  1. Help! Need a new coilpack!
    By SteveS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd January 2003, 22:29
  2. I.T. help please!
    By MisterD in forum General Chat
    Last Post: 20th January 2003, 21:19
  3. Please help, my hard drive has disappeared !!
    By sidicks in forum Home Cinema, Hi-Fi and Gadgets
    Last Post: 17th January 2003, 15:43
  4. Help Wanted - Amusing slogan
    By Moresauce in forum General Chat
    Last Post: 13th January 2003, 01:18
  5. Banner AD include help????
    By Administrators in forum General Chat
    Last Post: 7th January 2003, 15:21
