Sky InsuranceEM Tuning
    Apr 2013
    12
    Holding revs between gear changes
    Got a bit of a problem with my S3 2007 year. It seems to hold on to revs when driven quickly and changing gear. Ive done numerous google searches and the issue seems to be rife amongst 8L cars but no one mentions it on 8P.
    basically when accelerating hard and running through the gears, the revs dont drop very quickly giving the impression of riding the clutch. (the clutch is a new sachs stage 1 and it works fine)
    Any advice? Do the 8P cars still have clutch switch issues etc...
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    Worcestershire
    2,786
    I had this problem with my previous S3 8P (09).
    It was badly mapped. Had ECU put back to standard values and hey presto it worked like a dream again.
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
    Apr 2013
    12
    Quote Originally Posted by mjr901 View Post
    Mine is recently bluefinned so that may be a factor, thanks
    mjr901's Avatar
    Nov 2011
    Worcestershire
    2,786
    Quote Originally Posted by 1974nc View Post
    Every gear change used to make the car lurch forward, made it horrible to drive.
    Ask bluefin to put the values of the ECU back to standard.
    If no change re upload bluefin and hunt down a different problem.
    My money is certainly on the map though.
    Absolutely identical to the problem I had.
    Apr 2013
    12
    Update - thanks chap, it was the bluefin remap causing rev hang!
    mjr901's Avatar
    Nov 2011
    Worcestershire
    2,786
    Thought so!!!
    Go REVO, Shark or Rick at Unicorn. they'll do it properly.
  1. 2007 Audi a3 2.0 TDI 170 Revving up between gear changes!! HELP Please!
    By davsmith64 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th February 2013, 12:47
  2. Acceleration hesitation between gear changes
    By lucksta in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th May 2012, 20:55
  3. Over revving between gear changes
    By g dawg in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th May 2011, 17:02
  4. Holding Revs Between Gears
    By Lovegroover in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st August 2006, 15:41
  5. Clutch Switch - Revs Hanging on Gear change
    By h3msy in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th October 2004, 11:38
