Badger5Volks Autos
    Jun 2012
    HELP!! Revving S3
    Hi guys,
    Ive got an 08 plate S3 with 43.5k miles, on the drive into work this morning the engine is revving itself it goes up to 1.5 - 2k every minut or so when the car is in neutral. Also the rev needle is irratic keeps moving on tick over. Never had this before has anyone had such a problem before?
    Any help would be great.
    Thanks.
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    These tend to be caused by a vacuum leak.
    Jun 2012
    Quote Originally Posted by MrLapou View Post
    Thanks, is that quite common? is it easily detected?
    Jan 2012
    Stoke
    68
    It won't be a vacuum , it's a very common problem and also a very easy fix , £50 ish parts and very easy to fix your self. It will more than likely be the pressure relief valve I think it's call and seal.
    Problems :( Irratic idle issues
    have a read of that thread
    Jun 2012
    Quote Originally Posted by Lil ad9 View Post
    Thanks mate, well I took it down to my local Audi "specialist" and on the diagnostics machine its coming up with the following faults - thees a misfire on all cylinders and there is air leak somewhere and something about the throttle body. Sorry for the vagueness but thats all I got from them.
    Any clues as to what this could be before they fleece me??
    Jan 2012
    Stoke
    68
    Have a read of the thread I linked and its worth replacing the parts mentions as will probably cost you less than getting audi to scan your car and could very possible fix the problem.
  1. 2007 Audi a3 2.0 TDI 170 Revving up between gear changes!! HELP Please!
    By davsmith64 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th February 2013, 12:47
  2. 1.9tdi(110) not revving, help needed ASAP
    By Lex in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd March 2009, 21:21
  3. Please help, my hard drive has disappeared !!
    By sidicks in forum Home Cinema, Hi-Fi and Gadgets
    Last Post: 17th January 2003, 15:43
  4. Help Wanted - Amusing slogan
    By Moresauce in forum General Chat
    Last Post: 13th January 2003, 01:18
  5. Banner AD include help????
    By Administrators in forum General Chat
    Last Post: 7th January 2003, 15:21
