Any retrofitters going to AITP?
Chris, get yourself to scottish car show on the 21st july at the secc, Nigel will be there. :) x
Reactions: a6_chris and NHN
I'd happily drive up to do the install, but I wouldn't be going to the show otherwise.
Running those wires through the boot into hatch is a pita, one I do for the sb led lights, all worthwhile just takes time.
Reactions: a6_chris
It would be a job like anyother Chris, so would be specific travel to do the work.
Depends on what setup you're expecting as there's the OPS overlay setup or the standard rvc, as long the rvc r8 module doesn't have any obscure coding we're not aware of, then should be fine, will take time to run cables through the boot lid, but can be done.
You would need to confirm if you want it done & the parts you've secured so its not a wasted expensive journey for you :)
Eh your going to the show whether you like it or not......dont want a mad Scottish axeman on yer hands do ya??????????
Ok everyone, you're a witness, Braveheart over here has verbally threatened me :p
Which show Mark?
Reactions: Sandra
