Volks AutosEM Tuning
Results 1 to 30 of 30
Like Tree5Likes
  • 2 Post By a6-chris
  • 1 Post By ryanstewart9
  • 1 Post By a6-chris
  • 1 Post By RobbieWebs
Thread: RNSE AMI (Audi Music Interface) Retrofit Guide ..
    Jan 2012
    1,594
    This guide will show you how to retrofit Audi Music Interface into a 8P A3 with a MK2 LED RNS-E, part number ending in 193.
    Parts needed:
    - Audi RNS-E - PN 8P0 035 193 - Any letter after the 193 is fine, just make sure it's a MK2 as AMI WILL NOT work with a MK1
    - A glovebox with a CD changer slot
    - Chorus/Concert/Symphony/RNS-E Stereo removal keys
    - 8mm socket
    - Flathead Screwdriver
    - Some cloths to protect various trim pieces
    - VCDS / VAGCOM
    - Patience (!)
    - AMI -> Device lead (search eBay for AMI ipod, AMI aux, AMI USB, AMI mini usb etc.)
    Difficulty - 4/10 It's basically Plug 'n' Play but you do need VCDS which is a must
    Time Needed - ~30 mins
    Before we start, lets enable AMI in VCDS.
    Step 1 - CAN Gateway Coding
    - Before we install the hardware we will change the VCDS settings first so you can test the setup before making the final install.
    - Go into Can Gateway (19)
    - Coding (07)
    - Have a look through the options and look for 2E Media Player 3
    - Tick this and close
    Step 2 - RNSE Coding
    - Go into Navigation (37)
    - Coding (07)
    - Look for the 6th digit in your original coding - 0205715 and +1 to this value.
    - So using the above (this is my RNSE, please check your own), my new coding will be 0205725
    - Save and close.
    Now reset the RNSE.
    - Adaption
    - Using the drop down menu, look for System Reset (or similar), test and save and the RNSE will reboot.
    Save and close.
    At this point connect the plug 'n' play loom loosely and connect the long black wire to the AMI unit and plug in a Device so we can check everything is working before the install.
    Press MEDIA on your RNSE and press the Source button (upper right key) and select the option at the bottom of the list. If no device is connected it will say "No device Connected" or similar.
    Connect your device and in my case, it will display Chris' iPhone, press this and you should see your iPod (or USB memory stick) appear with all content.
    If this works, continue.
    Step 1 - Removing Stereo
    Place something over your gearstick (preferably have it in Neutral) to protect it from scratches as you'll be setting the Radio on this.
    If you have an Automatic/DSG car, place the lever in to N.
    - Insert your radio removal keys into the four corners of your RNSE with the arrows pointing inwards.
    - Please note, for the top left slot, you will have to retract the RNSE screen which can be done using the button beside the power/volume button
    - You will hear a click and this is the keys located correctly.
    - Do all four and pull the RNSE out.
    - Disconnect your antenna cable and quadlock whilst resting the RNSE on the gear stick.
    We have now removed the RNSE and should be left like this :
    Step 2 - Removing Glovebox
    - Remove the end panel on the end of the dashboard on the passenger side - this pops off (place in boot for safe keeping)
    - Now get your 8mm socket and remove the bolt shown below
    - Now open your glovebox and you will see the 8mm bolts you need to remove to allow the glovebox to be free'd.
    - Don't fully remove the bolts until the lower bolts have been removed fully - see below for location
    - Now once those have been removed you can remove the rest of the inner glovebox bolts - the glovebox will now drop but support it incase it's damaged.
    - Remove the cable(s) going into the glovebox - don't turn the ignition on until these are reconnected as it will cause an AirBag warning light to appear which will need cleared.
    - We have now removed the glovebox successfully
    Step 3 - Connecting AMI Module
    - Get your Plug 'n' play loom and connect this to the existing quadlock connector which came out of your RNS-E and feed the long black wire to the gloebox area whilst pushing the rest of the loom down towards the rear of the AC unit.
    - Slot the AMI unit into the glovebox until it clicks and attach the wire to the rear of the AMI unit.
    - Now re-attach your glovebox by doing the reverse of Step 2.
    - Slide your RNSE unit back in until it clicks and now enjoy your iPod/iPhone/USB through your headunit in nice OEM style.
    Any questions please ask below.
    Thanks for reading.
    ryanstewart9 and reepers like this.
    ryanstewart9's Avatar
    Sep 2009
    Surrey/Hants/Berks
    436
    Great write up Chris.
    Any chance you know the part number for that glovebox?
    a6-chris likes this.
    "If you ain't first, you're last!" - Ricky Bobby
    2008 A3 S-line 2.0 TDI PD140 (Pre-facelift)
    Jan 2012
    1,594
    The one I got was 8P2 857 035 A, I do know that 8P2 857 035 G will also fit.
    Don't bother looking in Germany, a left hand drive glovebox wont fit (this begins 8P1 I believe).
    I stalked eBay for must of been 3 weeks until the right one came up in Black. I checked morning and night on the newly listed under "Audi A3 glovebox" and finally one appeared.
    Of course if you have a CD changer already fitted or the crappy iPod interface, you're sorted glovebox wise.
    ryanstewart9 likes this.
    Jonse's Avatar
    Oct 2012
    353
    If you dont mind me asking how much was the glovebox?
    This is something ive always wanted to do
    Jan 2012
    1,594
    I got that one for £59 delivered.
    Sep 2009
    Surrey/Hants/Berks
    436
    Thanks Chris, may have to start stocking up parts lol.
    Unfortunately I have the standard glovebox like your original one (with the airbag switch on the far right).
    Sep 2013
    6
    Hi from the other side of the pond..
    I have a 193 RNS-E and OEM BT successfully retrofitted on a 2004 A6 C5 allroad. I am looking to retrofit CAN AMI as well using the 8P0 057 785 kit, but first want to confirm that it will work on this car. afaik my car has no CAN gateway. I sort of confirmed this by trying to open module 19 in VCDS - no response from controller.
    Can anyone point me in the right direction here?
    many thanks
    Jan 2012
    1,594
    I think it just needs a can feed from the RNSE, which the loom I used provides. Same as a B7 A4 and code the RNSE to show that AMI is connected, no other changes needed afaik.
    Sep 2013
    6
    if true that would be incredible mate! need to roll the dice I guess. my concern is around the can gateway coding instructions in this guide.
    - Coding (07)
    since there's no can gateway in my car I obviously can't do them..
    Jan 2012
    1,594
    Well this guide is for a 8P A3 so thats the instructions for this particular car.
    Have a look on the forum, I'm sure it was on here I seen it.
    AMI on a B7
    1,868
    You don't need a can gateway to get AMI working, I've got a MK2 RNS-E fitted to my B5 A4 and have AMI working, you just need to connect the infotainment can-bus wires from the RNS-E to the AMI.
    Sep 2013
    6
    Quote Originally Posted by B5NUT View Post
    alright! first confirmation I've seen online anywhere that AMI-CAN works on A4B5. Nothing yet for A6C5, but that's a great sign. will post back with my results.
    THANKS!
    1,868
    No reason for it not to, I take it you have already taken the infotainment can-bus wires from the back of the cluster to the RNS-E, if so just take them wires and link into the AMI. I even get the AMI song names showing on my DIS, link to my B5 install. What have you done today?
    RobbieWebs's Avatar
    Apr 2013
    Scotland
    680
    Another great write up Chris, deffo make things easier with ur instructions and pics
    I'd like but this tapatalk doesn't let me
    Audi A3 2010 2.0 TDI 140 Black Edition
    Sep 2013
    6
    Do the track names show up on the RNS-E as well? it does on MMI systems.
    Also have you tried an AMI BT dongle like the Viseeo WMA1000? It definitely works with MMI systems. Their website shows the song/album info displaying on RNS-E display just like the SD cards.. Tune2Air WMA1000 Bluetooth Music Receiver, Support Airplay, Audi-A2DP, Mercedes-A2DP and VW-A2DP - PRODUCT - ViseeO Worldwide Official Site?
    Jan 2012
    1,594
    Quote Originally Posted by bradnic View Post
    Yes all track names show on rnse.
    Advancedincar on the forum sells these, do a search.
    Sep 2013
    6
    Quote Originally Posted by a6-chris View Post
    confirmed ViseeO Tune2Air (WMA 1000) - Bluetooth Streaming over Audi AMI
    already bought one. testing it on this car and an E46 M3. looks like it's a winner!
    THANKS CHRIS
    Phil-1's Avatar
    Sep 2013
    Harrogate
    884
    This is another mod I want to do. I have the Aux plug near the handbrake. Will the Aux still work?
    I have an A3 8P MY09 TDI S Line
    Audi A3 8P Sport Back 170BHP (And I Love it)
    web page: philseagus.co.uk
    E-Mail:info@philseagust.co.uk
    Sep 2013
    6
    Quote Originally Posted by Phil-1 View Post
    You lose aux when you install AMI. AMI supports multiple connect methods though - iPod, USB..
    Phil-1's Avatar
    Sep 2013
    Harrogate
    884
    Thanks so would need to find a blank for it then
    Phil-1's Avatar
    Sep 2013
    Harrogate
    884
    Does the RNSE play CD's?
    All I can find is information about AMI and SD cards.
    1. If I install just the RNSE mk2 will I loose the ability to play CD's and loose the AUX near the hand break?
    2. The AMI is this just a set of leads that allows you to plug I-Phones/I-pods in
    3. Can you fit a 6 CD changer instead of the AMI?
    I'm looking at getting all the bits together over the coming months, then installing it or getting some to do it.
    Jan 2012
    1,594
    1. You can still play CD's but then you won't be able to use your nav. Not sure on the AUX but you can get a AMI->3.5 if needed
    2. All in my first post
    3. Yes but not sure if the changers play MP3 cd's.
    Phil-1's Avatar
    Sep 2013
    Harrogate
    884
    Thanks Chris
    So all I needs is
    1. RNSE mk2
    2. Appropriate conversion leads
    3. New glove box
    4. AMI leads or CD Changer ( might go for the CD changer as I do like my CD's)
    And not forgetting a lottery win😃
    Jan 2012
    1,594
    Yes.
    However you don't need a MK2 for cd changer, a mk1 will handle it fine but MK2s are much nicer
    Phil-1's Avatar
    Sep 2013
    Harrogate
    884
    I would like to have parking sensors fitted front and rear at some time, but I think they will only work with mk2
    Sep 2012
    Prague, CZ
    88
    I saw an option in VCDS when coding my AMI + MK2 RNS-E for for AUX port monitoring... i am wondering if you could piggy back the L+R+GRND connections for the AMI with the AUX port into the rear of the RNS-E , and then with this option enabled the AMI may auto switch to AUX IN when something is connected to the AUX port?
    The other option is the bluetooth adapter for the AMI, allowing you to connect devices to the AMI via Bluetooth.
    2009 A3 TDI 170 STronic SLine
  28. #27
    Dec 2009
    Thanks for this guide I managed to install a ami that I paid £140 on ebay.Bought the plug and play lead from kuftech for £40.My can gateway did not have the option of the media player in 2e . Thankfully the ami still works and is so much better than the CD .
  29. #28
    Wicked666's Avatar
    Feb 2005
    Leeds
    565
    Is album art displayed using AMI?
    Thank
    S3 Sportback
  30. #29
    Jan 2012
    1,594
    Quote Originally Posted by Wicked666 View Post
    Thank
    Not on the 8P, no.
  31. #30
    Wicked666's Avatar
    Feb 2005
    Leeds
    565
    S3 Sportback
  1. MY10 - Audi Music Interface thru RNS-E
    By Lima in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th April 2013, 22:39
  2. AMI - Audi Music Interface - Anyone got this?
    By NHN in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th November 2010, 21:58
  3. Audi Music Interface (AMI) for A3
    By JohnS3 in forum Parts Requests
    Last Post: 26th April 2009, 10:33
  4. Audi Music Interface
    By h5djr in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th January 2008, 18:42
  5. Audi Music Interface
    By nigelepotter in forum A5/S5/RS5 Forum
    Last Post: 8th January 2008, 20:20
