EM TuningBadger5
Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By JPK
Thread: Facelift tails issue
    JPK
    May 2012
    278
    Can only get the fog light on the inner facelift lights to work, otherwise they are not coming on at all. The outside are working fine for everything. I want it to work like a facelift car.
    The adaptor looms I used from 'tuning fanatics' had a 4th wire coming out of them that I connected up as an earth so that may be wrong?
    Any help would be appreciated as I have to give this vcds back to a mate tomorrow!
    Coding used:
    Btye 9 to Dec = 0 - as the final brake light
    Byte 10 to Dec = 0 - Fog lamps as a taillight
    Byte 12 to Dec = 36 or 48 - dimming rear standlight
    Byte 19 Bit 2 Cold Diagnosis rear active - this must be activated
    2005 A3 2.0T DSG Oettinger Body Styling, 19" RS5 Reps, APR Stage 1, Forge Twintake, Remus catback, BSH PCV Fix, 034 Motorsport Mounts, WALK, Whiteline bushings (F&R), Whiteline RSB, Whiteline BSK, Whiteline adjustable end links, H&R Sport Cup Kit, Stoptech Drilled Rotors, Hawk Pads, Tyrolsport stainless lines, Tyrolsport Calliper bushings, Tyrolsport DeadSet Subframe kit.
    JPK
    May 2012
    278
    Ok after more hunting around I think my issue was that the extra wire I earthed needs to be connected to 12v... Can anyone confirm?
    where would I get 12v from easily in that area?
    Oct 2012
    Warrington, North West
    986
    Do you have a 12v boot socket?
    JPK
    May 2012
    278
    Yes but that won't really work as the inners are in the hatch. Will have to remove the entire trim piece which I was trying to avoid then I guess and use the number plate light power
    Oct 2012
    986
    Surely there's a 12v live going to the inners anyway, and what adapters have you gotten?
    JPK
    May 2012
    278
    There is a 3 wire plug for the original inners and 4 wire for the facelift plug, the 4th wire is separate from the rest of the loom.
    These ones:
    danb986's Avatar
    In awe of VCDS
    Apr 2011
    Hertfordshire
    505
    If they're the Kufatec harnesses then they should've come with instructions. The separate wire is connected to the number plate lights to supply power to the inner LED's
    Now: 2010 A3 SB S-Line Black Edition 2.0TDi 140CR. Panther Black
    Retro'd: Black S-Line badges | Private Plate | Come home lights activated | Fogs as corning lights activated | Hill hold assist activated | TPMS (via VCDS) activated | 3.5" s/s tailpipe | LED interior lighting.
    Gone: 2007 A3 SB Sport TDI 140. Dolphin Grey
    JPK
    May 2012
    278
    Success
    danb986 likes this.
    Oct 2012
    986
    Looking good, how much did they cost?
    JPK
    May 2012
    278
    230gbp or thereabouts including adapters
    Oct 2012
    986
    Dis you get them from German eBay?
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,407
    get it from this guy:
    AUDI A3 8P SPORTBACK FACELIFT LED-RÜCKLEUCHTEN NEU OE! | eBay
    same guy i got mine from
    A3 Sportback 2.0TDI
    Dark Headlining, Bose, Alcantara Leather, Interior Lights Pack
    MODS:
    S3 facelift,
    RS3 Grill, 19" RS6, TTRS FBMFSW, A5 S-Line Heated Seats, Bi-Xenons, Auto Lights & Wipers, Eibach Sportlines, Auto Folding & Dimming Dumbo Mirrors, S3 brakes, US Centre Console, Cruise, Pioneer HU, Reverse Camera, OEM Parking Sensors, LED Tail Lights, S3 Pedals, Tints, Carbon Trims.
  1. 3dr facelift tail lights
    By V6Pete in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th May 2010, 19:55
  2. Facelift tail light fitting
    By Oranoco in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th May 2009, 20:55
  3. VAGCOM HELP ON A3 FACELIFT TAIL LIGHTS
    By thejolster in forum VCDS (formerly VAG-COM) forum
    Last Post: 22nd May 2009, 20:42
  4. A3 Model 8P Facelift Tail Lights
    By RGC in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd November 2008, 19:02
  5. Facelift tail lights
    By AlexStanley in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th October 2008, 18:59
