AH FabricationsChris Nott
Results 1 to 8 of 8
    Mar 2013
    Edinburgh
    15
    Audi Concert not working after window regulator replacement
    Good day all,
    As above, I have just replaced the window regulator on my drivers side, connected everything back up, all screws in place and everything was fine.
    However, now my radio will switch on, play for about a second then fade out and only slight distortion noise is heard. Radio has been taken out and put in my other car, which works fine but as soon as its put back in the A3, nothing.
    Can anyone provide some advice?
    thanks in advance.
    Car is a 2004/5 A3 1.6FSI if thats of any use.
    26,747
    Disconnect battery, then reconnect after few minutes, see if its got all confused, check you haven't caught any wires in the door, that may cause some abrupt reaction from other systems.
    Mar 2013
    Edinburgh
    15
    Unfortunately tried disconnecting, but still not working. I've contacted Audi and just waiting on a response now.
    Taken off the door card and everything is in order. Surely cant be something to do with ECU?
    26,747
    Ask Brodster if he can scan it for you as he's up your way.
    Mar 2013
    Edinburgh
    15
    Thank you, I'll see if I can give him a shout.
    Hopefully there will be no more silence!
    Jan 2012
    SW London
    751
    Checked fuses? panel between dashboard and drivers side door
    2006 Audi A3 2.0 TDI S-Line 8P2 PD170 - Dolphin Grey Metallic - The problem child
    1994 VW Golf VR6 - Mystic Blue - The money thief
    VCDS User
    Mar 2013
    Edinburgh
    15
    Checked all fuses and completely stumped as to what it could be. Usually pretty good with problem solving when it comes to my a3 but this is really bugging me. Everything powers up as it should, I get a seconds worth of sound then dips out. Might check the amp and see if it's powering up properly. Anyone know where that's located?
    Jan 2012
    SW London
    751
    behind the nearside boot panel. If ur running a non bose system u'd still get sound from headunit. If ur running bose then everything runs from the amp. What stereo have u got in the car? Are all the speakers standard? and have u checked the speaker connections on the door u changed the window regulator on?
    VCDS User
  1. Help! Electric windows/convertible roof/central locking not working after service!
    By chanatellav in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd April 2013, 15:42
  2. Cruise not working after battery replaced
    By juddster in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 15th July 2012, 22:32
  3. Front (RHS) Window Regulator replacement
    By necroeire in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th September 2011, 16:46
  4. HELP!!! CONCERT NOT WORKING
    By raffhussain in forum In-Car Entertainment
    Last Post: 14th July 2011, 12:52
Tags for this Thread
