Volks AutosAH Fabrications
    Jun 2013
    A3 engine management problems
    Hi
    Got a A3 2.0 tdi 07 plate. Engine keeps going in to idle mode when I reach a certain amount of revs, a warning light on dash and a whistle from the engine, is the turbo shot? cracked pipe? faulty seals?....Help!!
    Had engine cleaned, by this I mean I paid £120 to a garage to spray an aerosol cleaner down an air intake pipe, didn't work..
    Jun 2011
    Great Melton Norfolk
    1,349
    Get it scanned with vcds.look in vcds users section map to see if there is anyone near to you who can scan it.
    I assume you mean it goes into limp home mode? Could be vanes on Turbo need cleaning properly.
  1. A3 2004 TDI sport engine vibrating problems
    By rob1178 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th April 2009, 22:24
  2. help - engine temperature problems!
    By AudiSport in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th November 2008, 01:09
  3. Engine Management Problems - have I bought a dud?
    By mrmacmusic in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th April 2008, 12:23
  4. A4 1.8TQS engine mount problem?
    By SimonN in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st February 2008, 19:52
  5. Engine light problem =x
    By markyp2002 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th November 2006, 10:28
