Sky InsuranceBadger5
    Wilky5's Avatar
    Feb 2013
    32
    TDI 170 Turbo dying
    Hi All,
    I know there's been a lot of posts about this, spent the last half hour searching and can't find what I'm after.
    I've got a 2007 A3 TDI170 SLine. It's had a whistle for quite a while, which is getting worse. I've had intermittent white/blue smoke and intermittent kangerooing in traffic - oh and occasionally a lumpy idle.
    It's thrown into limp mode twice, had a friend read it and its coming back as boost pressure and I'm in need of a new turbo.
    Are recons any good and where's the best place to supply/ recon my turbo in West Yorkshire.
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    745
    Check its not your intercooler hoses that are leaking or the seals on the hoses are doing their job properly as they can cause the same issues.
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted... Still....
    Wilky5's Avatar
    Feb 2013
    32
    Thanks max. I had allege hoses checked in the hope it might be that - unfortunately not
    Wilky5's Avatar
    Feb 2013
    32
    Anyone got any ideas?
  1. A3 2.0 TDI 170 is the turbo gone ?? ** pics inside **
    By xtremedetailz in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th July 2013, 15:00
  2. A3 170 tdi hybrid turbo ?
    By dazjones in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd June 2013, 14:32
  3. TDI 170 - need new turbo ASAP!
    By eddscott in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 27th November 2012, 09:28
  4. A3 TDI 170
    By Karcsi in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th January 2006, 21:14
  5. 1997 A4 1.9 Tdi Quattro - turbo noise
    By Holywood in forum The Welcome Section
    Last Post: 26th August 2003, 15:10
