AH FabricationsSky Insurance
Results 1 to 10 of 10
    coreythorny's Avatar
    Mar 2013
    Leicestershire
    425
    Random intermittent beep when starting S3
    I have a manual 57 plate S3 and over the past week, twice its beeped when turning the engine over.
    I get no faults, lights etc and its intermittent, just a random beep not every time I start the car.
    I have no idea what it could be, weather isn't freezing so can't be a warning for that? Only thing I can think is I'm liftingi he clutch a bit early before Its fully started? I have no idea.
    Any suggestions? I don't have any access to VCDS/VAGCOM to run any scans just wondered if anyone knew any possible things to check.
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,487
    If you need vcds scan done, have a look at the vcds map link below for members near you. x
    https://maps.google.co.uk/maps/ms?ms...ce=embed#bmb=1
    danb986's Avatar
    In awe of VCDS
    Apr 2011
    Hertfordshire
    505
    Both my A3's have done that on random occassions. I've scanned with VCDS and all's clear, so I think it must be something to do with the timing of when I turn the key. It's almost like it's about to show something on the DIS and then you turn the key and it gets confused.
    Even my A3 courtesy car did this once now I think of it.
    Someone suggested previously that it might be something to do with the battery getting low, but after my old A3 was parked for 3 weeks it didn't do it when I first started it so I'm not sure if it's that to be honest.
    Now: 2010 A3 SB S-Line Black Edition 2.0TDi 140CR. Panther Black
    Retro'd: Black S-Line badges | Private Plate | Come home lights activated | Fogs as corning lights activated | Hill hold assist activated | TPMS (via VCDS) activated | 3.5" s/s tailpipe | LED interior lighting.
    Gone: 2007 A3 SB Sport TDI 140. Dolphin Grey
    Aug 2007
    Swansea
    82
    On start up my car beeps sometimes and displays an ESP Errorfor a second or two on the DIS.
    I asked the dealer about this and they said there was anAudi document stating that it is a known “feature” of the car and just ignore it.
    danb986's Avatar
    In awe of VCDS
    Apr 2011
    Hertfordshire
    505
    I'm only guessing, but it sounds like the start up is interrupting some sort of self diagnosis the ESP is performing at the time.
    Mar 2013
    Leicestershire
    425
    Quote Originally Posted by XPOWER View Post
    Could well be, the ESP light is showing on the dials during start up, but then again I believe it does regardless?
    I'll have a play over the next few days and try and diagnose if it's due to a start up time, i.e rushing the procedure or turning the ignition, pausing then starting.
    Oct 2012
    LEEDS
    81
    do you have any handsfree device in oyur car? it might be that
    ''With great power comes Great RESPONSIBILITY'' - Spidermans Uncle
    Mar 2013
    Leicestershire
    425
    Quote Originally Posted by Happy View Post
    Yeah I have RNS-E with bluetooth and the handsfree phone cradle bolted on the dash which is just a big eye-sore.
    But its not that "bong" which you get when the phone connects, it's just a single clear beep.
    Oct 2012
    LEEDS
    81
    I have a aftermarket handsfree kit in my car and when i turn the ignition on thes a lound single beep and thats its. Even if i quicky start the car its stills there. i got told by my mechanic that its the handfree kit...because its an aftermarket it beeps to tell you its on.
    bmh.01's Avatar
    Apr 2012
    Nuneaton
    279
    If you want the car checking over with VCDS let me know i'm not too far from you.
  1. 2004 3.2 A3 Quattro, 3 Beeps when Starting
    By paulclaude in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th April 2013, 15:17
  2. Rear wiper wipes randomly when starting up
    By vimy in forum New A3/S3 (8V Chassis)
    Last Post: 26th December 2012, 15:52
  3. 4 beeps when starting S3
    By S3MHT in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th June 2007, 13:07
  4. noise when starting
    By JamesA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th May 2004, 08:02
  5. S3 Beeping on start up
    By ben in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th September 2003, 12:22
