JMB RetrofitsAH Fabrications
Results 1 to 7 of 7
    Feb 2013
    262
    Dogbone bolt size?
    can someone tell me what size the bolt is that I need to remove to fit my powerflex insert? I read online that its 21mm but it's baggy as hell on the bolt but I don't have a 20mm so can't try it without buying one
    Audi S3 : revo stage 2+
    autolatry's Avatar
    Jan 2013
    Yorkshire
    347
    I was just under the car I could have checked.
    Ill check in the morning and report back if no one else replys beforehand.
    Feb 2013
    262
    Thanks would appreciate that
    tdi-man's Avatar
    Jul 2009
    1,612
    IM TAKING my insert out had it in a for a while and its to clunky when u start and in reverse
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs /
    233 bhp - 309 ft lb - 419 nm (NEEDS A NEW MAP)
    autolatry's Avatar
    Jan 2013
    Yorkshire
    347
    It is 21mm pal.
    Feb 2013
    262
    ok so I did it with a 21 mm spanner but I had to use a long one as it was bloody tight, there's no way I could loosen it using a socket. I fitted the powerflex red which is recommended for diesels (mine is s3) as I didn't want more vibration.
    After a road test I'm pleased to report that there is no additional vibration infact there's less, with only oem you could feel that the car was running when at idle and if you have a few revs the car would move slightly, this is now gone and it feels very smooth at idle, whilst driving things feel a little tighter and more direct including throttle input etc but it's nothing dramatic, certainly worth the price tag though, I'd bet in a fwd only application that the benefits would be even better as I don't get wheel hop with the Quattro/Haldex
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    939
    I'm replacing the whole dogbone mount, audi charge £35 for the whole part.
    VCDS USER
  1. Audi S3 Dogbone Bolts
    By djx11b in forum Parts Requests
    Last Post: 21st November 2011, 12:58
  2. what bolt size for my spacers!!!
    By dplovin in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th August 2011, 23:46
  3. Bolt Size
    By CMD in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th May 2011, 05:28
  4. seat belt bolt size
    By Plunky in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th March 2011, 17:40
  5. Bolt size for the hub on a 1999 A4 Quattro Turbo
    By swsimon in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th June 2004, 18:56
