Sky InsuranceEM Tuning
    Apr 2013
    100
    What should the BTDC be ona bkd?
    In the wngine measuring blocks i think its either 15-4-5?! One of those it says BTDC mine says 0.0 BTDC is that okay? Its winding over longer before it starts and it starts with abit of a miss for a couple of seconds!
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    685
    When warming up from stone cold (under 50C) injection will be around 1-2 degrees BTDC, this then retards as the car heats up to around 4-5 degrees ATDC.
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted!
    Bits for sale...
    Genuine S-line 18" alloys, A3 Sportback rear lights. A3 5dr window switches & mirror switch. , Brand new PD170 engine cover. PM for details.
    Apr 2013
    100
    Mine stays at 0.0 BTDC. How is this ajusted? Mt torsion value in on 0.5 ant idle consumpion is 0.4-0.6 l/h.
    max69vk's Avatar
    Apr 2012
    685
    What group are you getting your readings from in VCDS?
    There's a whole host of thing that will affect this figure, rpm, temp, fuel quality etc as the ECU will constantly be adjusting though the warm up phase. One thing you definately dont want is a figure in BTDC when warmed up as its runs the risk of pushing the crank rotation in the wrong direction!
    Bits for sale...
    Apr 2013
    100
    I think its group 4 or could be 5 or 15. Ha, i have droped the idle speed to 819 rpm to cure the rough idle would this be why its taking longer to crank into life?
  1. what should the ign be on vag com o idle
    By karls s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd June 2011, 19:06
  2. Replies: 9
    Last Post: 25th September 2010, 05:24
  3. What colour should the coolant be?
    By Hightower in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st November 2009, 20:56
  4. What should I expect from the 1.9tdi (130) CVT Auto?
    By amimmortal in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 3rd February 2009, 12:15
  5. What should the misses drive?
    By dazzatdisport in forum General Chat
    Last Post: 13th November 2004, 17:55
