EM TuningBadger5
Results 1 to 11 of 11
    Jun 2013
    Cumbria
    202
    When should the cooling fans kick in?
    Hi guys,
    just replaced my cooling fans on my car but I have only heard one of them go once I think?!
    Does anyone know when each of the two fans are meant to kick in? I just took it for a 15 minute drive and only heard what sounded like a fan once when I pulled over.
    i thought these would run more? The temperate outside is very average and raining
    2003/2004 Audi A3 2.0 TDi Sport
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    2nd one is for when the Aircon is on, so i would say thats normal...
    Jun 2013
    Cumbria
    202
    Thanks very much, Even though I'm in the wrong section
    VAB
    VAB's Avatar
    May 2012
    Australia
    44
    Found this when checking mine & trying to determine why my fuse kept going
    FAN PROBLEM - POLL SYNOPSIS - uk-mkivs
    May 2013
    39
    Sorry for hijacking the thread but im having problems with my fan on 2.0FSi 2004 the large noisier fan comes on as and when it wants quite random really car isn't over heating nor loosing coolant and fan always turns off when the car turns off can anyone shed some light on this? thanks
    Zak0123's Avatar
    Apr 2012
    Cambridgeshire
    460
    I only hear my, what sounds like the larger fan, come on when I switch the engine off after I've had my foot down/90+ for 10+ minutes or so. Sometimes it switches off after a few seconds and sometimes it stays on for a couple of minutes, depending on the drive.
    Brilliant Black 61 Plate A3 1.6 TDI
    Mods: S3 BE 5 Spoke Rotor Wheels with Goodyear EfficientGrip
    , AppRadio 2, 80% tints, Diamond Vision Headlights
    Jun 2013
    Cumbria
    202
    ahhh i see, i may have to take it for a long drive then! I have heard the aux fan should come on when you press the aircon button but mine doesnt activate like that? the ambient temperature outside was fairly cold when i did this though, could this have an affect?
    Apr 2013
    Aberdeenshire
    594
    Quote Originally Posted by Tommy53 View Post
    Does your ac work properly
    Jun 2013
    Cumbria
    202
    I think so, im pretty new to the audi but Do i just turno the ECON light off and press the circulation button with the A next to it? Well whatever i do i feel cold air come in..
    Apr 2013
    Aberdeenshire
    594
    Your fans should run with the a/c on especially if the a/c is on and fully charged easily indicated by the suction pipe sweating it sounds like you bought a bad egg you seem to be having loads of issues cooling system related have you checked for flow and are all your hoses hot
    Jun 2013
    Cumbria
    202
    Hmmm couldn't agree more. Im having so many issues with this car and none of which seem to be cheap!! I haven't mate ill have a look tonight
  1. What RPM should the A3 170 pd spool up/kick in at???
    By Simon170TDI in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st September 2012, 17:02
  2. When should you change the water pump on the s3?
    By drfeelgood in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th August 2010, 22:55
  3. When does the turbo kick in?
    By spannah in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th January 2008, 15:53
  4. when should the timing belt be changed for A4?
    By loktian in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th December 2007, 10:08
  5. When does the turbo kick in?
    By jxm96c in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th November 2003, 09:37
