Sky InsuranceBadger5
Thread: EML
    Apr 2013
    Kettering, Northamptonshire
    172
    EML
    I did copy the vcds fault code but ive accidently copied something else since and deleted the fault code, every now and then it comes up with intake manifold flap, anyone come across this and how to fix?
    TDI140's Avatar
    May 2011
    1,350
    Replace it with new intake manifole flap/ throttle body the big silver bit with plug in it under the egr valve about £180 from euro car parts ive done it on mine
    A3 2.0TDI FWD sportback with GT1756 250.3bhp 336ft lb, forge boost hoses red, milltek decat system, BMC panel filter, golf gti edition 30 full front brakes brembo pads, black honeycomb grill, full oem s line kit + cupra r lip, LED side lights, OEM xenons, LED interior lighting, LED A8 number plate lights, boost gauge, alloy catch can with red hoses, FBSW, windows tinted, de-badged, now on air ride with chassis notch BBS CH
    TDI140's Avatar
    May 2011
    1,350
    Apr 2013
    172
    Ok cheers, is it worth cleaning out? Notice and performance improvements?
    TDI140's Avatar
    May 2011
    1,350
    No need to clean, u need new one once its broken its broken get from euro car parts and clean EGRvalve as it will be off
  1. Cam shaft sensor = EML
    By chrissy1502002 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st March 2010, 10:51
  2. EML light, strange
    By tonyjohnson in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st November 2009, 19:48
  3. How to get the 'PSSSSSTTTT' With No EML Light
    By wibble111 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th July 2009, 10:42
  4. EML staying on
    By Matt in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th July 2009, 20:04
  5. EML - multiple misfires
    By noelg100 in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th September 2008, 15:10
