Chris NottMonster Motorsport
Results 1 to 12 of 12
    Oct 2012
    Aldershot, Hampshire
    190
    Loosing oil somewhere!!!
    Recently I have noticed I'm putting 1l of oil in my car every 4-5 weeks, I have looked all around/under the engine and cannot see any obvious oil leaks anywhere.
    Could it be the seals in the turbo have gone around the intake compressor wheel causing oil to be drawn into the system or heavy breathing from the engine putting oil out through the breather?
    There is no blue smoke coming from the exhaust!
    Any ideas?
    It's a 2005 a3 2.0 tdi with 95k miles
    Jun 2013
    Cumbria
    198
    Is there any black smoke when pulling away or mainly on a cold engine? And if you push the accelerator right to the floor and let go a few times does it puff out black smoke?
    2003/2004 Audi A3 2.0 TDi Sport
    sliced's Avatar
    Drive safe, stay alive.
    Jun 2012
    1,162
    Radiator?
    Current: 8P3 '59 2.0 TFSI 3DR S-Line | Adaptive Bixenons with DLR's | Folding electric mirrors | Heated half leathers |
    Previous : '06 2.0 TDi Sportback in Dolphin Grey| SE | DSG | Satnav | Privacy glass | auto lights | comfort pack |
    Oct 2012
    190
    There used to be quite a bit of black smoke until I put new glow plugs and had a new intercooler fitted. The old one was full of suit and oil.
    Jun 2013
    Cumbria
    198
    Rightio, well when my turbo started to fail I got block smoke. This was from the oil in the turbo that had leaked past the seals when the car was stationary. Most garages will check your turbo for you for fairly cheap. They can take a pipe off and feel the movement in the turbo shaft and this can tell you if you have an issue there.
    Oct 2012
    190
    Ok might be an idea. Thinking of going hybrid if this one is nakered. 😃
    Jun 2013
    Cumbria
    198
    yeah im looking at turbos at the minute also, im thinking of going hybrid but then im also thinking is this going to wear my clutch out quicker?
    Oct 2012
    190
    I'm pretty sure my clutch needs doing soon so I'm not worrying about the clutch. Found complete Sachs clutch and flywheel kit on euro car parts for £200
    crazylegscrane's Avatar
    May 2008
    London
    145
    Mine did a litre of oil after an oil change service at Audi, it was picked up when I had my clutch fitted at APS, they told me the plastic housing around the oil filter was cracked and the oil was leaking onto the sump guard if I remember right, I never noticed any oil under my car. I took it back to Audi and they sorted it - was p155ed with them though...
    S3 Sept 08 to.....
    A3 2.0 TDI Sport April 04 - May 08
    Oct 2012
    190
    I still haven't found the cause for loss of oil but the pipe from my rocker breather is swimming in oil and I'm starting to worry that the rings are shot and its heavy breathing
    Brodster's Avatar
    Shark Performance In Scotland
    Mar 2011
    Scottish Borders
    3,217
    Follow Brodster On Twitter Add Brodster on Facebook
    Have a look at your fuel filter because if your tandem fuel pump has failed the oil tends to get drawn into the fuel system due to the pressure differential. This is what happened to my 140TDI. Oil light came on which I thought was a little weird and sometimes it used to kangaroo slightly as in jumpy but not all the time. Turns out it was the tandem fuel pump. Its bolted to the top right hand side of the engine. The fuel filter is the long cylinder to the left of the engine....just undo the 8 allen key bolt screws and remove and withdraw the filter.....If sludgy then theres your problem.
    Angelwax/BBS/BCS/Bilstein/Cobra/CTS Turbo/H&R/K-Sport/KW/Loba/Milltek/Shark Performance/Oz Racing/VCDS/Wagner
    Oct 2012
    190
    I changed the fuel filter a few months ago and it was sludgy inside. But no one could give me any ideas why. Is there anyway to test the pump. 2 of my injectors have failed as well 😟
  1. LOOSING OIL HELP!
    By Yaseen1991 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th October 2012, 20:10
  2. 1.9 TDI is loosing oil.
    By DonNiger in forum Diesel forum
    Last Post: 29th January 2007, 20:49
  3. Loosing oil
    By 90_quattro in forum General Technical / How To
    Last Post: 18th April 2006, 19:44
  4. Oil Filter loose.
    By darrenp in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th October 2005, 22:41
  5. A Home for Oil Burners?
    By danksy in forum Classic Audi Forum
    Last Post: 2nd January 2003, 16:08
