AH FabricationsJMB Retrofits
Like Tree4Likes
  • 1 Post By Geraldy212
  • 1 Post By wuta3
  • 1 Post By NHN
  • 1 Post By Lz36
Thread: More Problems :/
    Feb 2013
    London
    20
    More Problems :/
    Last week my battery was pretty much dead, at the time of this I had a lot of friends getting in and out of my car moving the passenger seat backwards and forwards and when I started the car the Air Bag light came on and hasnt gone off since.
    I had a friend scan my car and it came back with the following code. He tried clearing it but the light still stays on the dash.
    1 Fault Found:
    01218 - Side Airbag Igniter; Passenger Side (N200)
    001 - Upper Limit Exceeded - MIL ON
    Any suggestions?
    Thanks in advance
    Sportback owner
    Apr 2007
    France
    492
    Sounds like you may have a connection problem with the side airbag. Worth while taking a good look at the wiring loom that feeds the side airbag, and check wires and plugs. Upper limit exceeded may be a sign of an open circuit. Good luck.
    Lz36 likes this.
    French A3 Sportback 2006, 2.0L 140 TDI, DSG, RSN-E, Ambient lighting, Auto-lights/wipers, Reverse assist, Dolphin Grey, 17" wheels, Leather seats, Cruise control, Roof bars.
    wuta3's Avatar
    Jul 2012
    Manchester/Sheffield
    1,064
    somebody probably just snagged out the connector under the seat. Put the seat in the back position and lift the flap to check. You may need the airbag fault coded out tho.
    Lz36 likes this.
    ​​Programmer/Web Developer, Headphone/Amp Geek
    06 SLine Special Edition Phantom Black 2.0T FSI Quattro A3
    Done: P-Flo, RevD, Sachs Organic, Milltek TBE + Res + Sports cat
    Wanted/Next:Intercooler, HPFP, Remap
    Feb 2013
    London
    20
    Thanks for the replies. I checked the wiring under the seat and they seem to be fine and havnt been pulled out.
    27,097
    It is probably losing connection momentarily or the wiring has pulled in the seat or under, so as wuta states check seat connectors properly or inside the seat there is another connector hidden.
    Lz36 likes this.
    Feb 2013
    London
    20
    All sorted, had the connections under the seats replaced. Quick fix luckily! Thanks for your help though
    NHN likes this.
  1. More problems argghh!! misfiring on idle....
    By will.f_1.8t in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd November 2009, 16:01
  2. More Problems - Starter Motor this time
    By d4mo in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd May 2009, 17:05
  3. New gearbox and clutch kit. More problems....Please Help!
    By bhavin1986 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th October 2008, 07:13
  4. MORE PROBLEMS
    By AUDI TURBO in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st January 2008, 18:11
  5. more problems
    By petewon in forum General Technical / How To
    Last Post: 22nd July 2006, 14:36
