Rui Carneiro
hi there..
.in the last summer i have some iddling problems in my audi...what happens is that once i stop and the engine is in iddling rpm (+/- 900), after 30 sec, it starts to accelerate whithout touching the throtlle, staying in 1000/1100 rpm, besides this, the radiator fans start to work, even if the car is still cold....then if i hit the throtlle hard, ithe fan stop, and the iddling is in the 900 rpm like it should, however after 30 sec, accelerates again...so, i´ve changed a temperature valve, that one that its under the air filter box, and the problem was solved...
however in the past week the problem returns...with the same symptoms, exactly the same, and i´ve changed the same valve....but in this time, didnt work....the problem persists....
i leave you a log with the vag com version 10.6...
18051 - Please check DTC Memory of Electric Load Controller
P1643 - 000 - - - Intermittent
Freeze Frame:
RPM: 1575 /min
Torque: 160.0 Nm
Speed: 0.0 km/h
Load: 37.6 %
Voltage: 13.98 V
Bin. Bits: 11000000
Load: 32.5 %
(no units): 1.0
thank you...
RC
PS: hope this the correct spot to leave this kind of question....
Freeze Frame:
RPM: 1575 /min
Torque: 160.0 Nm
Speed: 0.0 km/h
Load: 37.6 %
Voltage: 13.98 V
Bin. Bits: 11000000
Load: 32.5 %
(no units): 1.0
thank you...
RC
