JMB RetrofitsEM Tuning
    Jun 2013
    Problem with after market stereo ..... Help needed
    Rite... got my self a 2007 S3,
    I have just put in a pioneer app radio 2 with apple tv and WiFi,
    all works sweet and as expected.
    the problem i got is something to do with the volume speed controle
    from the bose speaker and amp set up in the car.
    i have removed the mic in the over head console with map lights etc
    but the volume still increase when i go faster.... i want to be able to
    controle the volume my self and not as my car thinks it should be.
    it is most annoying.... and i got to drive to france in it soon.
    any one any idea what or which wire needs plucking out
    cheers in advance matt
    27,096
    It needs wiring modifying to disable the audiopilot system.
    Aug 2008
    138
    Can you not turn it off in the settings of the stereo?
    if you've got a Quadlock connector I think the GALA/V-Signal/Speed signal is on pin 3 of the blue B connector:
    OEM Bluetooth retrofit into A4 B6 help required
    Or if you've got ISO type connectors it might be pin 1 of the A plug:
    MCD Navigator and stock CD changer
    8P2 A3 2.0T FSI S line Special Edition Sportback S tronic 2007MY. Black. Concert II+ & Bose.
    27,096
    That wont help as he has an aftermarket stereo which doesn't support audiopilot, so there wont be a setting anyway.
    Gala etc wont help, its audiopilot.
  1. Dice mediabridge with concert 2+ stereo help needed
    By Dba359 in forum In-Car Entertainment
    Last Post: 27th February 2013, 11:37
  2. Help! Removed after market stereo and now Airbag light is on!
    By col6821 in forum In-Car Entertainment
    Last Post: 6th June 2011, 23:29
  3. Problem with Temp Warm-Up(Help Needed Please)
    By THE MONSTER in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd February 2010, 12:22
  4. Standard Audi Alarm with after market one?
    By Markb in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th March 2005, 21:24
  5. After market Stereo Install
    By Naresh in forum TT/TT-S/TT-RS Forum
    Last Post: 20th November 2004, 18:22
