Chris NottVolks Autos
Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By Chillout
Thread: seem to be loosein coolant
    Jun 2013
    barnoldswick
    hi I have a 56 plate a3 tdi 170 Quattro the coolant warning keeps coming on if I open the bonnet with the engine running the header tank is empty but if I turn the car off and remove header tank cap the coolant returns to a normal level also there seems to be quite a lot of pressure when I remove the cap
    Any help would be much appreciated as it has been to a few local garages n they cant find a leak
    cheers
    26,750
    Welcome to the site.
    It needs putting under pressure to about 1.25-1.5 bar to see where its coming out from, if at all & the way you've explained is normal for all cars when releasing pressure with lid of reservoir, get someone with the right tool to test the system under pressure.
    Apr 2013
    Aberdeenshire
    584
    Sounds like you have a air lock have you tried running it with heating on full and the header cap off and check your return line at the top of the header for flow if you are not adding coolant you can't have a leak I would try pinching hoses .
    however if you are adding coolant pressure test as above .
    NHN likes this.
    Jun 2013
    barnoldswick
    it has been pressure tested and they found a leak that part has been replaced and had no warning come on for a bit but then after a while started coming on again. It has had a bit of coolant added but not a lot think I will try running it with header cap off thanks
    Apr 2013
    Aberdeenshire
    584
    Mine took ages to purge properly a was shi@&ng myself I probably drove for 200 miles the removed the cap when stopped to let air out squeezed hoses ect.
    Jun 2013
    barnoldswick
    hope this works as it has been an on going problem for a while and very frustrating beeping all the time. When I removed the header cap the other day still had a lot of pressure even after being stood for over 12 hours is that normal???
    Apr 2013
    Aberdeenshire
    584
    At least if its still under pressure 12 hours later its sort of a pressure test in away
  1. Audi a4 TDI 130 Problem Coolant Seems Bubbly SEE PIC
    By samsam in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th January 2013, 12:39
  2. V6 coolant temp sensor & idle speed control valve
    By JDA in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd March 2004, 18:27
  3. S3 Coolant warning
    By Mike.M in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th January 2004, 21:02
  4. Coolant Temp Sensor
    By teknobod in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 22nd January 2004, 11:14
  5. Coolant pipes
    By Seizure in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th January 2004, 23:10
