EM TuningChris Nott
    Jan 2013
    Sudden Loss of oil in engine.
    Evening,
    Have 2006 2.0tdi A3 sportback 107,000m. Normally on the 20,000m service the oil lasts but sometimes at around 18,000 the fuel economy shoots up for one tank and then the engine sounds more rattly then normal and then the oil light comes on. The oil used is the correct oil. Why would this be, does the oil suddenly fail ?
    Except this year when the car was serviced 5000m, in Feb, but the above pattern just happened, after just the short time.
    Have had other diesels over the years and have all acted differently. And I do not normally have to keep topping up. There are no leaks and no noticably bad things comming from exhaust, MOT in march. Quite a mix of motorway and country road driving but I dont race or go mad on motorway (Dont hang about though)
    Should I worry ?
    Apr 2013
    Aberdeenshire
    584
    Quote Originally Posted by Rupert Barnes View Post
    Evening,
    Should I worry ?
    bad pcv,blocked breather or turbo seals possibly.
    26,749
    Welcome to the site.
    I wouldn't even leave the engine oil to 20k ever, 10k is the safer bet, given how oil is the life blood of the engine to stop wear, better to change it more often.
    To clarify, you're saying the engine oil light has come up after 5k?
    If so then maybe it wasn't filled as much on last service, just top it up & see how it goes from there.
    Mr. B's Avatar
    English...not so good
    Jan 2012
    Bristol
    873
    I've had my 2.0TDI for 4 years and it loves to drink oil. I do a lot of miles though. I think it's normally
    Jan 2013
    What I am also interested to know is regarding the life of the synthetic oil and the sudden fall off of protection. Would it be fair to say that at some point the structure can fail, either due to wear or temperature ? and this is what pushes up the MPG, by 20%, as it gets burned away ? My engine oil does not go down slowly, it always happens in this way.
  1. sudden loss of power with 1.9 TDI engine
    By VAGMAN1 in forum Diesel forum
    Last Post: 21st September 2009, 15:46
  2. Sudden loss of power on 1.9 TDI engine
    By VAGMAN1 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 11th May 2006, 19:36
  3. Sudden loss of power on a TDI engine
    By VAGMAN1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th February 2006, 00:11
  4. Sudden loss of power on TDI engine
    By VAGMAN1 in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th February 2006, 18:57
  5. Sudden loss of boost
    By AudiA4rulz in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th December 2004, 18:26
