Sky InsuranceEM Tuning
Results 1 to 15 of 15
    Feb 2013
    11
    Alarm Siren Intermittent
    Hi Guys,
    Just got a small issue that's starting to really bug me,
    My 2004 A3 alarm will only go off when I central lock my car BUT the alarm is intermittent and it doesn't always go off...like this morning parking up for work it never went off when I central locked it...but last night about 8ish this alarm kept going off when I tried to lock it..and on the odd occasion it wont turn off even when I unlock the car...I need to turn the ignition on to turn it off, but thats the odd occassion that happens.
    Can someone please help??
    Marchy
    Apr 2013
    Aberdeenshire
    595
    Scan it with vcds mine did this the other day not scanned it yet but it could be the back up battery in your alarm module do you hear beeping in the car no the full volume of the alarm just a beep.
    Feb 2013
    11
    Hey,
    Nah no beep...just the alarm. I was thinking it could be a faulty siren maybe? Or could it still be the battery? As it doesn't happen all the time...so annoying lol!!
    leeds2592's Avatar
    When I grow up, I want a 964!
    Apr 2012
    Leeds
    1,184
    Visit leeds2592's Instagram Channel
    Mine started doing this a few weeks back. It started going off for now reason in the middle of the night then a couple of days later, the alarm would go off but only the lights, no siren. Scanned it with VCDS and with a bit of research it seems as though I need to replace the siren which is a bit of a PITA to get to and replace.
    Get it scanned with VCDS so you can see what codes coming up and take it from there. If you clear the code, it may just fix the problem.
    Black 2007 2.0 FSI Sport
    2011 Glossy Black RNS-E |AP Coilovers | 18" 7 Spoke OEM BE Alloy Wheels | H&R Trak+ Spacers 8mm (Front) 12mm (Rear) | MY11 Rear Lights | S Line Spoiler | Retrofitted MFSW | Retrofitted Cruise Control | Interior LED Light Pack | OEM LED Numberplate Bulbs
    27,126
    Yes the siren is located in a real pita location, not a job I would like anyone to have to do, but as above could be variety of things, convenience module, siren, wiring etc, so get it scanned.
    Feb 2013
    11
    Where is the siren located?
    Might have a look at getting a new siren for it.
    27,126
    Scan it 1st, then consider siren, as could be wasted job.
    leeds2592's Avatar
    Apr 2012
    Leeds
    1,184
    It's located somewhere in behind offside wheel arch from what I've read.
    As myself and Nigel have said, get it scanned and take it from there instead of replacing something that might not need replacing!
    autolatry's Avatar
    Jan 2013
    Yorkshire
    347
    Mine does this. Got this fault when it was scanned.
    There are two horns on mine one on either side of the engine bay (low level).
    Its just another thing on the list for me. The horns aren't expensive.
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433
    Component: KSG H02 0040
    Coding: 198800186D288505485AC63000
    Shop #: WSC 06435 000 00000
    VCID: F9F21A8AB068CED0E62
    Part No: 1K0 951 605 A
    Component: LIN BACKUP HORN H01 1201
    Part No: 1K0 907 719
    Component: Neigungssensor 002 0002
    Part No: 8P0 951 177
    Component: Innenraumueberw.H03 0010
    2 Faults Found:
    01134 - Alarm Horn (H12)
    004 - No Signal/Communication - Intermittent
    27,126
    I think you're confused with the actual car horns, not the siren mate, on pre mid 08 cars it had 1 each side of the lock carrier, facelift cars moved both to drivers side, the actual siren remains a single one.
    autolatry's Avatar
    Jan 2013
    Yorkshire
    347
    Ahh. I forgot about the horn horn. Of course. Ha
    So the two red horns are the horn sounders nowt to do with the alarm.
    Any ideas where the alarm is on the 3.2 as the above indicates it's goosed does it not?
    Not a lot in my engine bay ATM and I haven't noticed it.
    27,126
    Red, they're usually black, unless you're being funny :P
    autolatry's Avatar
    Jan 2013
    Yorkshire
    347
    99% sure they are red. Hmmmm , I'm gonna have a look in a minute.
    27,126
    Maybe you wish they were lol
    autolatry's Avatar
    Jan 2013
    Yorkshire
    347
    Just checked them. They are black. FFS, need to lay off the mushrooms I think lol.
  1. alarm siren A3 tdi 1999
    By noddy tt in forum Diesel forum
    Last Post: 18th August 2006, 12:29
  2. Alarm Siren
    By james0808 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st May 2006, 23:07
  3. Feeble alarm siren...
    By SimonP in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th February 2006, 18:35
  4. Alarm siren help
    By matt116 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th August 2005, 13:04
  5. Alarm siren
    By LeeW in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd May 2005, 19:31
Tags for this Thread
