Sky InsuranceEM Tuning
    37
    37's Avatar
    May 2013
    Area 51
    118
    Part # for MFSW or FBSW
    I would like to know the part number for MFSW or FBSW and airbag for 2007 1.6 A3 Sportback - whichever ones fit.
    27,033
    You need to advise us which wheel type you have, round or flat bottom, pics help, also if round, then you need to remove your current airbag & take pics of underneath as there are 2 types being used, excluding the fbmfsw version.
    37
    37's Avatar
    May 2013
    Area 51
    118
    It is a 4 spoke steering wheel at the mo without any sort of MF and NO DIS either. I am looking to change it to a MF or FB, whichever one I can find cheaper (eBay FTW), hence my request for part numbers for either so that I can snap up when something comes up.
    As for airbag, is there a way to find out using the VIN #? I am only looking for a steering with airbag, so I suppose if the steering wheel can work, airbag will come with it, else I won't be buying it.
    P.S. I am aware that I need the steering module ending in F as well.
    27,033
    Ah complete wheel, well that's different.
    Are you interested in a supply/fit solution as we can do the lot, if interested ping me a PM
    37
    37's Avatar
    May 2013
    Area 51
    118
    Don't need the whole fit / solution - Just the part numbers which are compatible
  1. need help for parts required for mfsw
    By audiA3Noob in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th March 2012, 00:12
  2. Part Number for MFSW
    By solaris in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 15th April 2010, 09:32
  3. After market body parts for A4
    By in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th July 2004, 22:57
  4. Painting parts for cheap
    By Holywood in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th September 2003, 15:31
  5. I need the part # for 310cc injector..please
    By austurbo in forum Tuning
    Last Post: 1st August 2003, 11:04
