Chris NottAH Fabrications
Like Tree1Likes
  • 1 Post By Chillout
Thread: Is my flywheel failing?
    Jan 2012
    1,599
    Okay so getting this funny noise from the car (1.9 TDI, BLS engine code) with a KBL 5 speed gearbox when releasing the clutch when setting off.
    You can also hear it when the car is stationary with the window down.
    Currently on 69k.
    I found this video of a BKC engine Golf which shows the same symptom and noise my car is experiencing.
    I've also noticed recently that sometimes second gear is a bit jumpy when releasing the clutch back out.
    The clutch doesn't slip or judder.
    I know I can't avoid the DMF but surely not at 69k?
    Jun 2013
    46
    I think that is normal what i heared!The flywheel is rattling when you leave the clutch!So if you think there a problem may is the clutch bearing!It's difficult to hear the sound from a video!
    Isaa's Avatar
    Aug 2012
    South London
    102
    Hi
    I have a 1.9 TDI and have the exact same issue. When the cars idling a rattle can be heard coming from the engine bay but when the clutch is pressed the noise disappears. The car is also very jumpy when moving off from first gear and I occasionally get a slight slip. I was thinking of going to Europarts to buy a whole clutch kit to resolve this issue.
    Clutch Kit | Quality Clutch Kits for any car | Car Clutch Kit
    Apr 2013
    Aberdeenshire
    580
    Quote Originally Posted by Isaa View Post
    Hi
    I had a seized dmf on my 59 plate passat 2.0 tdi 140 bhp it took two years and vw uk to put a bit of pressure on the dealer my car had 9k on it at its first visit when I told them my flywheel was causing my lumpy idle
    Ers_GTTDi likes this.
  1. Brake failed
    By kenny15 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th February 2004, 15:40
  2. Why did the boost fail ?
    By rickquattro in forum General Technical / How To
    Last Post: 24th December 2003, 19:33
  3. Droplinks - how long til they fail ?
    By Fraser in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th October 2003, 20:34
  4. 02m flywheels
    By prof in forum TT/TT-S/TT-RS Forum
    Last Post: 2nd June 2003, 21:34
