Chris NottJMB Retrofits
    Nov 2012
    14
    vag error codes?
    Hi,someone scanned my a3 06 and found these errors
    The oil level sensor i changed it to a new one but same error
    I dont wanna buy a air quality sensor if i dont have to of someone can explain me the errors meaning
    2 Faults Found:
    00562 - Sensor for Oil Level/Temperature (G266)
    008 - Implausible Signal
    Freeze Frame:
    Fault Status: 00000011
    Fault Priority: 6
    Fault Frequency: 254
    Mileage: 56963 km
    Time Indication: 0
    Date: 2012.10.08
    Time: 02:43:00
    010 - Open or Short to Plus
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 109
    Mileage: 52793 km
    Time Indication: 0
    Date: 2012.08.17
    Time: 14:41:29
    Nov 2012
    14
    This is the second part of the errors
    2 Faults Found:
    00819 - High Pressure Sensor (G65)
    009 - Open or Short to Ground
    Freeze Frame:
    Fault Status: 01101001
    Fault Priority: 3
    Fault Frequency: 145
    Reset counter: 224
    Mileage: 53208 km
    Time Indication: 0
    Date: 2012.08.30
    Time: 19:21:50
    Freeze Frame:
    Temperature: 29.5�C
    Voltage: 12.90 V
    RPM: 0 /min
    Load: 0.0 %
    Load: 9.0 %
    01592 - Air Quality Sensor (G238)
    Freeze Frame:
    Fault Status: 01101010
    Fault Priority: 3
    Fault Frequency: 27
    Reset counter: 224
    Mileage: 52500 km
    Time Indication: 0
    Date: 2009.04.12
    Time: 02:44:21
    Freeze Frame:
    Temperature: -50.0�C
    Nov 2012
    14
    Anybody?
    Apr 2013
    Aberdeenshire
    592
    http://www.volkspage.net/technik/ssp...SP_233_GB2.PDF. This link gives details of your oil sensor also check your bonnet catch read that it can cause issues also due to bonnet opening quantity however if you have a display it would show open on screen.
    your air quality sensor if it is faulty recirc function will not work
    your g65 fault relates to your high pressure switch on your condenser it in itself could be faulty or the wiring however it may also be ok and just doing its job to cut the supply to the clutch as you could have an air flow issue through your condenser such as radiator fans not operating hence it opening at it set pressure.
    27,099
    Check all 3 sensors for a common wire/fuse, maybe something has been damaged or you're just unlucky & have 3 sensors down, but as you've changed the oil one & still short to plus, then its pointing to the wiring/fuse.
  1. VAG.COM error codes - Any ideas ?
    By sbk1972 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 26th May 2009, 18:40
  2. VAG-COM Error codes
    By SonicDeathmonkey in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st January 2009, 19:49
  3. VAG error code. Please help.
    By moschino in forum General Technical / How To
    Last Post: 11th April 2006, 20:34
  4. VAG-COM - Lamp on dash, but no error code
    By AL_B in forum VCDS (formerly VAG-COM) forum
    Last Post: 16th November 2005, 14:59
