Volks AutosChris Nott
    wuta3's Avatar
    Jul 2012
    Manchester/Sheffield
    843
    Quote Originally Posted by stan 1 View Post
    hi all.. i am new to the forum and hoping somebody can help me out..
    I have a 2007 audi s3 which i have a few problems..
    1st.. when the car is on idle and i attempt to pull the dipstick out or take the oil cap of the car will start to struggle and go to cut out, i have heard people talk about problems with the pcv are thease any of the symtoms could it be the pcv valve??
    2nd..does anybody no the size of the steering arm nut size joins onto the track rod end think its a 36mm but not sure and wanting to by the spanner for it??
    3rd... and does anybody no what size spline socket it is for the driveshaft gearbox end was told its a triple spline but not sure and dont no the size as i am wanting to order a socket??
    4th i am in the process of removing my driveshaft i just cant seperate it from the hub i have removed the 27mm bolt etc i have tried hitting it with a mallet numerous times and left it soaking in wd40 for houres on end it just wont move has anybody had a similar experience are the splines on the driveshaft seized inside the hub???
    any help of the above will be greatly appreciated
    thanks.. regards stan....
    Welcome stan! I'm sure somebody will be able to help with this. In the mean time, get some bloody pics of ure car up! We love pics round 'ere
    ​​Programmer/Web Developer, Headphone/Amp Geek
    06 SLine Special Edition Phantom Black 2.0T FSI Quattro A3
    Done: P-Flo, RevD, Sachs Organic, Milltek TBE + Res + Sports cat
    Wanted/Next:Intercooler, HPFP, Remap
    Mar 2013
    30
    I also need to know driveshaft nut size, tuftys guide says 17mm male hex, however mine appears to have a different nut, looks like a 12point nut possibly 30mm
  1. what bolt size for my spacers!!!
    By dplovin in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th August 2011, 23:46
  2. Bolt Size
    By CMD in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th May 2011, 05:28
  3. seat belt bolt size
    By Plunky in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th March 2011, 17:40
  4. Steering arms & rod ends question
    By Fishy_bob in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th February 2010, 13:40
  5. Bolt size for the hub on a 1999 A4 Quattro Turbo
    By swsimon in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th June 2004, 18:56
