EM TuningChris Nott
    Breezey's Avatar
    Hexxagon Champion
    Mar 2010
    Bridgwater
    430
    BKD 2.0 TDI Boost / Random Airbag light Isuue
    Hi all,
    Was halfway back from a long drive today of about 250 miles when i noticed a change in the sound of the turbo as i had the windows open, sounded alot more wooshy / the sound of air escaping, i had a lack of power at times but for the most part i had a decent amount of boost. i carried on a few miles and thought to myself if there was a boost issue surely it would throw a code and i would see a light? boom no sooner than i thought it i got a light but to my amazement it was the airbag light randomly linked to lack of power?
    My diagnosis is a boost hose has a split / come loose but not having ramps etc im unable to check until tuesday, im abit miffed as to why the airbag light has come on so looking for ideas really and a possible confirmation of my diagnosis? dont have VCDS yet unfortuinatly but considering purchasing it now to help with this as ive used it alot in the past.
    26,722
    VCDS is your best bet atm tbh, as we're merely speculating over the net.
    Breezey's Avatar
    Hexxagon Champion
    Mar 2010
    Bridgwater
    430
    If your willing to do me a deal i will have a copy if you dont mind me picking your brains every now and then? :P
    26,722
    Its already the deal of the century anyway :P
    Price is the same for all buyers, nothing more or less
    Breezey's Avatar
    Hexxagon Champion
    Mar 2010
    Bridgwater
    430
    PMed. Would you say my assumption is along the right lines tho? is it going to cause me much harm driving with the boost leak? i have it somewhere in the back of my mind that as theres no vaccume now the turbo can overspool and damage itself?
    26,722
    Airbag light sounds little strange, but could be an IC pipe popped of or split hose, ideally a scan 1st then check pipes, as its 2 different systems.
  1. 2.0 tdi Boost Problems BKD 140
    By Jack_tdi in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th June 2013, 16:26
  2. Airbag light and Rear Wiper on my A3 TDI Sline 3 door.
    By MisterP in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th June 2012, 22:06
  3. A6 tdi airbag light on! looking at purchasing car?
    By evomaster3000 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 8th January 2005, 21:57
  4. Airbag Light
    By ajmackie in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th March 2004, 16:18
  5. Horn / Airbag light problem
    By MikeS in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th February 2004, 17:46
