Sky InsuranceVolks Autos
Results 1 to 7 of 7
    Jan 2013
    Bolton, UK
    402
    Follow Aidy06 On Twitter Visit Aidy06's Instagram Channel
    VCDS scan log help
    Hi, I had my car scanned today for the first time since owning it. Big thanks to Mikemc.
    The log showed up 2 faults but neither of us had any idea what they where, Any advice on the fault codes would be much appreciated. Heres the full scan log...
    Sunday,09,June,2013,12:06:09:46857
    VCDS Version: Release 11.11.6 (x64)
    Data version: 20121223
    Chassis Type: 1K0
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 76
    VIN: WAUZZZ8P65A165875 Mileage: 181140km/112555miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: OK 0000
    76-Park Assist -- Status: OK 0000
    Address 01: Engine Labels: 06F-907-115-AXX.lbl
    Part No SW: 8P0 907 115 A HW: 8P0 907 115 A
    Component: 2.0l R4/4V TFSI 00 0150
    Revision: --H15--- Serial number: AUX7Z0E3FNH00I
    Coding: 010300031C070060
    Shop #: WSC 00618 210 91869
    VCID: 3069563DA3945A9890B
    1 Fault Found:
    001089 - EVAP Emission Control Sys
    P0441 - 001 - Incorrect Flow - Intermittent
    Freeze Frame:
    Fault Status: 00100001
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 181081 km
    Time Indication: 0
    Date: 2013.06.08
    Time: 10:14:59
    Freeze Frame:
    RPM: 756 /min
    Load: 14.1 %
    Speed: 0.0 km/h
    Temperature: 66.0°C
    Temperature: 22.0°C
    Absolute Pres.: 1010.0 mbar
    Voltage: 14.224 V
    Readiness: 0000 0000
    Address 02: Auto Trans Labels: 02E-300-0xx.lbl
    Part No SW: 02E 300 042 M HW: 02E 927 770 AD
    Component: GSG DSG 041 0820
    Revision: 04004010 Serial number: 00000504130079
    Coding: 0000020
    Shop #: WSC 06314 000 00000
    VCID: 1D379F89C406C7F02BD
    No fault code found.
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No: 1K0 907 379 K
    Component: ESP FRONT MK60 0104
    Coding: 0021126
    VCID: 3A7D741575E890C82EF
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 H HW: 8P0 820 043 H
    Component: KlimavollautomatH14 0180
    Revision: 181836 Serial number: 8P0820043H
    VCID: 316F5339A89E53909F5
    Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
    Part No SW: 8P0 907 279 C HW: 8P0 907 279 C
    Component: Bordnetz-SG H37 0301
    Revision: 00H37000 Serial number: 00000001819299
    Coding: 018C4F06A014100000000000000000000000FE075C
    Shop #: WSC 06314 000 08192
    VCID: 3D777F0964C6A7F00BD
    Subsystem 1 - Part No: 8P2 955 119 B Labels: 1KX-955-119.CLB
    Component: Wischer AU350 H01 0130
    Coding: 00062736
    Shop #: WSC 06314
    Address 15: Airbags Labels: 8P0-959-655-84.lbl
    Part No SW: 8P0 959 655 D HW: 8P0 959 655 D
    Component: Airbag 8.4ED H00 0140
    Coding: 0011603
    VCID: 438309F10222D1007D9
    Address 16: Steering wheel Labels: 8P0-953-549.lbl
    Part No SW: 8P0 953 549 B HW: 8P0 953 549 B
    Component: Lenksäulenmodul H21 0050
    Coding: 0011112
    Part No: XXXXXXXXXXX
    Component: Lenkradmodul H04 0040
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
    Part No SW: 8P0 920 980 TX HW: 8P0 920 980 TX
    Component: KOMBIINSTR. VDO H76 0350
    Revision: D08 Serial number: 2256GD08000021
    Coding: 0000410
    Shop #: WSC 00999 067 57207
    VCID: A049267D73746A1880B
    Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
    Part No SW: 1K0 907 530 D HW: 1K0 907 951
    Component: Gateway H08 0100
    Revision: 08 Serial number: 25001054118804
    Coding: 3F0F0740070101
    VCID: 2859BE5D9B44125848B
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Revision: D08 Serial number: AUX7Z0E3FNH00I
    Shop #: WSC 00618 210 83433
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN1.lbl
    Part No: 8P0 959 801 E
    Component: Tuersteuerger. H10 0040
    Coding: 0000048
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K2 909 144 H
    Component: EPS_ZFLS Kl.8 1502
    Shop #: WSC 00000 000 00000
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433
    Component: KSG H03 0040
    Coding: 198000186D288505489AC63000
    Shop #: WSC 00501 210 55518
    VCID: F9FF2B19B06EDBD0E75
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Part No: 1K0 907 719 B
    Component: Neigungssensor 004 0003
    Part No: 8P0 951 177
    Component: Innenraumueberw.H03 0020
    1 Fault Found:
    01134 - Alarm Horn (H12)
    000 - -
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN1.lbl
    Part No: 8P0 959 802 E
    Coding: 0000048
    VCID: 3E75780569C0BCE8127
    Address 56: Radio Labels: 8P0-035-1xx-56.lbl
    Part No SW: 8P0 035 186 C HW: 8P0 035 186 C
    Component: concert II EU H51 0100
    Revision: 01S Serial number: AUZ2Z3E2311787
    Coding: 0021201
    Shop #: WSC 06435 000 00000
    VCID: 326D5C35AD986888E6F
    Address 76: Park Assist Labels: 8P0-919-283.lbl
    Part No SW: 8P0 919 283 HW: 8P0 919 283
    Component: Parkhilfe 4-Kan H06 0030
    Coding: 0001003
    VCID: F8F92E1D8B64C2D898B
    26,747
    1st is clear them & test again, then check whats left, alarm horn could be batteries & the engine, just search online as common fault arises.
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,147
    As said, clear and scan again. You've had a remap recently, which didn't install too smoothly initially, so could be down to that.
    I had a couple of odd engine fault codes after remapping mine, but once cleared they never came back.
    Jan 2013
    Bolton, UK
    402
    They've been cleared, will try and get them scanned again next week to see if they have reappeared
    Tay
    May 2012
    Warrington
    324
    The P0441 is a common fault which is related to the evaporation circuit, and could be caused by leaks, split pipes, N80 valve or charcoal canister problems to name a few.
    This fault is sporadic in most cases and doesn't need immediate action IMO, but if it occurs frequently after being cleared I would investigate it thoroughly.
    May 2012
    RETFORD, NOTTS
    1,707
    Just saw this, thinking maybe this fault has returned?
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Jan 2013
    Bolton, UK
    402
    Quote Originally Posted by @udi A3 View Post
    It didn't cause the engine management light to come on last time though mate so I initially didn't think of that
  1. Anyone help with a VCDS scan south coast, Portsmouth-Brighton
    By RyanW in forum VCDS (formerly VAG-COM) forum
    Last Post: 28th July 2012, 15:35
  2. VCDS Auto Scan Log
    By Dan-Jnr in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th November 2011, 17:32
  3. St Albans Area VCDS Scan unit-HELP!!
    By stressfrees3 in forum VCDS (formerly VAG-COM) forum
    Last Post: 8th July 2011, 21:32
  4. Swindon Area VCDS Scan HELP!!
    By N7 JNS in forum VCDS (formerly VAG-COM) forum
    Last Post: 2nd June 2011, 11:09
  5. Help with VCDS scan
    By fad in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th December 2010, 01:09
