Badger5Sky Insurance
Results 1 to 8 of 8
Thread: clunk
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,480
    clunk
    1.6 2003 sport
    this is my daughters car
    seting off in 1st is smooth into 2nd smooth
    into 3rd clunk 4th clunk
    if it was a RWD id think prop
    clutch not slipping etc
    any ideas
    TIA.
    27,094
    The clunk is this when clutch pedal released or when gear lever goes into gear etc, more info required I'd say.
    bez101's Avatar
    Jul 2008
    8,480
    sorry was in a rush.
    its when im leting the clutch out .
    J3NKO's Avatar
    Dec 2009
    Swindon
    73
    I have just started getting this too, it's when the clutch is let out and the power is put back on.
    Dip clutch, shift, revs dropping, raise clutch to bite and transitioning to power, clunk, power
    its quite subtle like a pop before the revs are picking up again and the power is down.
    I don't get it on soft, easy shifts, only when the shift is quicker and with more power.
    27,094
    Could be subframe movement that others have complained about, there's a £200 kit from the US that apparently fixes this.
    J3NKO's Avatar
    Dec 2009
    Swindon
    73
    Subframe shift??? Sounds serious!
    Will get searching...cheers
    J3NKO
    27,094
    No its not vast, but the bolts are stretch ones & there is some space for minor movement back/forth, search on here for the thread as I cant recall name.
    PS. Will check your PM shortly.
    J3NKO's Avatar
    Dec 2009
    Swindon
    73
    Sure - already been through Welly's thread and that looked horrific, spent £1k chasing a clunk. I will NOT be doing that lol
    No probs fella
  1. Climate control clunking?
    By dik in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th December 2005, 23:52
  2. creaking / clunking sound (offside front) when turning right ?
    By LeeW in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th April 2005, 22:38
  3. Help needed for mysterious suspension clunks
    By mandymcconechy in forum Volkswagen and other VAG
    Last Post: 10th January 2005, 23:02
  4. Clunk from underneath car...
    By imported_ashs3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th October 2004, 21:23
  5. clunk clunk clunk!
    By imported_bennyboy in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th October 2004, 15:09
