    Nov 2012
    14
    2006 us model facelift
    Hello,I have a 2006 a3 north american base model and I'm doing a facelift to my car
    I tryed to find some diy but cannot find for my particular project
    I have done already the 2010 spedometer,led taillights,double din,facelift a/c dials,newer blower motor....
    I would like to know what else than fenders,hood,rad core support,grille,bumper and headlights, I would need for my project for the front end
    Someone told me I need rebar and brackets as well to change and for this
    Also i will put the led headlights,what exactly i have to do as the us model has a lot of things prewired already
    Anyone can give me some advice?
    27,029
    So you took the dash out to fit the new blower system to be compatible with the facelift climate, its the only way to make it work properly.
    Just do some research & reading on the site, its been discussed loads of times.
    Nov 2012
    14
    Well I took the glovebox and I was able to change the blower motor
    I put a 2012 golf blower version j and it seems ok (can't control the a/c for now cause I have an issue with the air quality sensor)
    I'll do some more search on the forum
    27,029
    The blower motor isn't enough, depending if the US adopted the later design, but only cars in EU from late 07/08 onwards supported pnp of the facelift climate unit, older systems will show issues.
  1. 2006 AUDI A3 FACELIFT CONVERSION ADVICE NEEDED
    By Cloth ears in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th May 2012, 13:34
  2. New Audi models/facelifts
    By Matt in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th December 2007, 01:11
  3. Removing Concert Head Unit in 2006 Model A3
    By Roswell in forum In-Car Entertainment
    Last Post: 6th October 2005, 22:40
  4. Does anyone have or know where to get A3 2006 Model Year PDF?
    By DaveS3Turbo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th April 2005, 17:19
  5. info on S3's (facelift model)
    By darkspin in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd June 2004, 13:45
