JMB RetrofitsBadger5
Like Tree1Likes
  • 1 Post By NHN
Thread: Dash light dimmer
    Feb 2013
    12
    Exclamation Dash light dimmer
    Afternoon Ladies and Gents
    It would seem that my dash light dimmer switch thingy isn't working anymore. My clocks are really bright, but my radio, heater controls and ambience lighting are seriously dim.
    When I operate the switch, nothing happens.
    Ive checked a number of fuses, but can't find anything directly related to this function. I haven't yet checked the plug/wiring on the switch yet, just thought I'd see if anyone had any ideas first?
    Any help would be greatly appreciated.
    53 A3 2.0 TDi if it makes any difference?
    Cheers. Arron.
    27,087
    Check the connector behind to see if its popped out.
    To get the headlight switch out, when at zero, push the dial directly in towards front of car, turn to 1 o'clock whilst depressed & pull the whole unit out whilst holding at this position.
    The speedo has a light sensor built in, which maybe why its bright still.
    Artimus likes this.
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,842
    Thank you for that nugget Nigel! it's always good to know these things - even before an issue arises.
    2009 A3 SB 2.0T DSG S line
    Feb 2013
    12
    Thanks Nigel, but unfortunately that doesn't seem to be the issue. Although I wasn't aware the unit could pop out like that. I thought I'd have to drop the front of the dash!
    I can only assume its the switch itself that's broken. The headlight levelling switch isn't operating either. Either that, or a fuse somewhere. I guess I'll have to get the power probe out and check everything.
    Thanks again!
    Arron.
    27,087
    Open the switch & see if the tracks have burnt out.
    You could always try bypassing the switch to test the circuit is fine.
  1. Dash light came on this morning, what does it mean?!
    By cha1n in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th April 2006, 13:29
  2. My dash lights seem permanently on - is this normal?
    By rgb8888 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th January 2006, 12:24
  3. Dash-Lights - can't see at night........
    By archicampbell in forum Classic Audi Forum
    Last Post: 8th December 2004, 10:04
  4. Heater Dash Lights
    By ratty in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st November 2004, 19:44
  5. DASH LIGHTING
    By imported_AudiAuto in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th August 2004, 21:16
