Sky InsuranceVolks Autos
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    933
    Brake Fluid Type And Quantity - 04 Plate
    Hi,
    What type of brake fluid is used on 2004 2.0TDI A3?
    Dot 3? Dot 4?
    Do you use any particular brands?
    How much of it is needed when changing?
    Thanks!
    VCDS USER
    coreythorny's Avatar
    Mar 2013
    Leicestershire
    406
    Normally says on the cap it self on the reservoir, failing that try the manual.
    JPK
    May 2012
    278
    Around 1.5L if you are also doing an ESP/ABS unit flush through diagnostics.
    I would recommend using OEM fluid only.
    2005 A3 2.0T DSG Oettinger Body Styling, 19" RS5 Reps, APR Stage 1, Forge Twintake, Remus catback, BSH PCV Fix, 034 Motorsport Mounts, WALK, Whiteline bushings (F&R), Whiteline RSB, Whiteline BSK, Whiteline adjustable end links, H&R Sport Cup Kit, Stoptech Drilled Rotors, Hawk Pads, Tyrolsport stainless lines, Tyrolsport Calliper bushings, Tyrolsport DeadSet Subframe kit.
  1. What brake fluid?
    By Markb in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th April 2005, 21:46
  2. Renewing brake fluid and coolant
    By comdw in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th March 2005, 17:35
  3. brake fluid
    By 17AUG2002 in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st February 2005, 09:25
  4. Brake Fluid Change
    By Masterm8fo in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th December 2004, 23:41
  5. Brake Fluid
    By AL_B in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st January 2003, 23:39
