Monster MotorsportVolks Autos
    Feb 2013
    37
    Audi A3 rear Wheel bearing replacement Hard job ?
    Hi , need to replace one of the rear wheel bearings on my car
    its the 2005 hatchback 2.0 tdi sport 140
    Is it a hard job ?
    Also where should i buy the part from as ive found this one on ebay :
    AUDI A3 1.4 1.6 1.8 1.9 2.0 TFSI TDI FSI REAR 5 STUD WHEEL BEARING HUB ABS | eBay
    I rang euro carparts up and they wanted over 100!
    Feb 2012
    Birmingham
    132
    I had to replace the whole hub on mine due to the abs ring perishing. Only problem i ran into was the spline socket needed for the hub nut...just brought the VAG Laser set.
    Mine is a 53 plate and id pulled off with ease, took me about an hour tops and I am no mechanic
    That ebay one looks different to the one i had to get..maybe they changed em in 2005?
    Got mine from GSF cant recall the price but a lot cheaper than audi. Also did you use the 25% off code for ecp?
    Jul 2012
    Cheshire/N Staffs
    709
    You might need the XZN or "triple square" bit. Google "XZN".
    Note this is not the same as multispline
    As for the part, Dave at Stoke Audi ail sort you out (see Stoke Audi section of the forum).
    S3 8V 3DR DSG ACC ABS ADS AMI ASR ASS DAB DBW DIS DRL EBA EBD EDL EGR EPB EPS ESP GPS LED MFSW MMI PDC PSF RAC SDXC TFSI CO2 EEC OTR WTF OMG
    Feb 2012
    Birmingham
    132
    Laser Tools | 4939 | Spline Bit Set - 1/2"D 6pc
    This is the set i got, only £20 from a local tool store. I think its the M16/M18 you need. I didnt want to risk it slipping and chewing the spline...what a nightmare that would be haha
    Feb 2013
    37
    Ok cool thanks for the quick response , maybe i should have mentioned its a 2005 but its the facelift model so will it be different?
    Thanks again
  1. rear wheel bearing replacement a3 18t
    By weelo in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th June 2012, 21:45
  2. HELP .. Wheel Bearing Replacement - Audi Main Dealer!!!!
    By c15luf in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 28th May 2012, 14:57
  3. A3 rear wheel bearing replacement queries...
    By richrich14 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th October 2011, 21:40
  4. Rear Wheel Bearing replacement.
    By P Crr in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 19th February 2010, 18:22
  5. Replacing rear wheel bearing
    By Leon in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th March 2009, 14:47
