Chris NottBadger5
    Apr 2013
    100
    Whats your cam timing bkd owners??
    As above, i want to rule out my cold start issue by setting the cam timing perfect! Ive heard 0.0 for torsion value and 0.6 l/h idle consumption for a up to temp engine. What are your readings? Thanks
    Oct 2012
    Warrington, North West
    986
    Where abouts in VCDS do I check this and ill let you know
    Apr 2013
    100
    Engin/ messuring block then group 15 and group 4. Thanks
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    745
    Aim for 0.5 on the BKD, seems to make it run a bit smoother & better low rpm pickup.
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted... Still....
    Apr 2013
    100
    Is that + 0.5 or - 0.5?
    max69vk's Avatar
    Apr 2012
    745
    Positive. VCDS only shows a - negative symbol, not a + for positive.
  1. Whats your mpg bkd owners??
    By Ade6 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th May 2013, 12:26
  2. GTI Project Game...Whats your time??
    By Nilz in forum General Chat
    Last Post: 12th May 2009, 00:38
  3. Replies: 36
    Last Post: 31st December 2008, 21:58
  4. S3 OWNERS!!whats your average mpg?
    By S4 Omz in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th July 2008, 22:00
  5. Wondering what your 1/4 mile times are!!!!
    By nicklght in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th August 2007, 12:25
