EM TuningJMB Retrofits
Thread: FOG LIGHT BULBS
    tdi-man's Avatar
    Jul 2009
    1,612
    FOG LIGHT BULBS
    THINKING of HID fog lights or H11 bulbs with resisters any body done this ?
    thanks
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs /
    233 bhp - 309 ft lb - 419 nm (NEEDS A NEW MAP)
    danb986's Avatar
    In awe of VCDS
    Apr 2011
    Hertfordshire
    505
    I guess that as you're thinking of fitting HID's to them that you're after the look rather than functionality on foggy conditions.
    I fitted LED's with resistors to mine and then set them to be used as DRL's using VCDS. They looked good and bright as DRL's, but don't put any usable light on the road. They wouldn't be any use in fog either, but I never actually needed them as fog lights.
    Here's the thread, but it might not be what you're looking to achieve though:
    LED Fog Light Bulb Resistors Fitting Guide
    Now: 2010 A3 SB S-Line Black Edition 2.0TDi 140CR. Panther Black
    Retro'd: Black S-Line badges | Private Plate | Come home lights activated | Fogs as corning lights activated | Hill hold assist activated | TPMS (via VCDS) activated | 3.5" s/s tailpipe | LED interior lighting.
    Gone: 2007 A3 SB Sport TDI 140. Dolphin Grey
    tdi-man's Avatar
    Jul 2009
    1,612
    carl-1968's Avatar
    May 2012
    Nottingham
    457
    Yep got the set of hid's off Trups and will post up some photos when done
    tdi-man's Avatar
    Jul 2009
    1,612
    Fog lights all wired up today with H11 bulbs of Trups.
  1. s3 fog light bulbs
    By 08080808 in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th August 2006, 12:19
  2. changing fog light bulbs
    Last Post: 21st December 2005, 13:43
  3. fog light bulbs
    By imported_kris_tdi in forum General Chat
    Last Post: 23rd November 2005, 19:05
  4. fog light bulb replacement?
    By imported_RELOADED99 in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th December 2004, 21:24
  5. Fog light bulb - quick question
    By K212 in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th August 2004, 02:41
