Volks AutosMonster Motorsport
Page 1 of 3 123 LastLast
Results 1 to 40 of 85
Like Tree7Likes
Thread: Going Stage 2+
    Jan 2009
    125
    Going Stage 2+
    I'll be going Revo stage 2+ in the next couple of weeks after buying milltek turbo back exhaust, ITG CAI and Autotech fuel pump and cam follower.
    Should i be uprating any other parts other than clutch, flywheel and clutch release bearing?
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,422
    worth replacing cam follower when doing fuel pump swap (especially if the car has few thousand miles).
    oh, and rs4 fuel pressure regulator does make a difference, it's cheap part but it requires some time, and work for changing as it's located underneath intake manifold. mine was done when the car was in for clutch change...
    pinterovski likes this.
    s3 Ibis White ... Build Thread
    / Black Grill / FbMfSw / Sunroof / Hill Hold / Armrest / Black Leather-Alcantara interior / Rear Parking Sensors / Heated Seats / Folding Mirrors / Cruise / Rns-e mk2 // ttrs-Brembo Brakes / 12mm spacers / Forge Short + Side Shift / 42dd's / ITG CAI / GfB DV+ / Forge Catch Can / Milltek TBE / Forge Twin IC/ Autotech HpFp / H&R ARB's / WALK / KW v3's / RS4 fpr / Loba&Sachs clutch / Revo Stage 2+ / ...
    Jan 2009
    125
    Quote Originally Posted by S. View Post
    What benefit does the RS4 fuel regulator give? Is it worth uprating the injectors, coil pack and plugs?
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,422
    well it gives little more power and torque after 5000-5500rpm (and gets rid of flat spot at those rpm's on more aggressive settings).
    injectors aren't needed as s3 ones flow more than enough for stage 2+. coil packs aren't needed too. maybe spark plugs if they've been long on car before...
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,406
    Quote Originally Posted by gilberto View Post
    As below,the S3 injectors will take you to around 400bhp and maybe a little more,so they'll be fine.
    Stick with regular changes of stock plugs and you'll be OK on those.
    The only thing I'd add is to make sure the brakes and suspension are up to the job.....the stock stuff is a bit near it's limits at this sort of power.
    Jan 2009
    125
    How regular would you change the plugs?
    wuta3's Avatar
    Jul 2012
    Manchester/Sheffield
    1,075
    Doesn't stage2+ require an uprated intercooler or is that just non-S3 cars?
    ​​Programmer/Web Developer, Headphone/Amp Geek
    06 SLine Special Edition Phantom Black 2.0T FSI Quattro A3
    Done: P-Flo, RevD, Sachs Organic, Milltek TBE + Res + Sports cat
    Wanted/Next:Intercooler, HPFP, Remap
    DJ-S3's Avatar
    Apr 2009
    Wakefield
    683
    Quote Originally Posted by wuta3 View Post
    I know for a S3 you don't need one but I've got one anyway. Too cheap to turn down :D
    pinterovski's Avatar
    Oct 2010
    661
    Add pinterovski on Facebook
    Uprated or extra intercooler makes a big difference when stg2+!
    Black roof,Tinted windows,Solar Orange Calipers,KW V3 Coilovers,
    HEKO Wind Deflectors,CAI ITG Maxogen,Non Res Supersprint Exhaust CB with custom Fi76mm DP,
    RevD with GFB DV+,Autotech HPFP,Custom SKN map Stage2,Forge ShortShifter,THS mounts,
    Twintercooler,Clutch is now on LOBA/SACHS!!!
    18 OZ Ultraleggera!
    365HP and 500NM of torque!
    phil76's Avatar
    Feb 2008
    SHEFFIELD
    562
    Quote Originally Posted by pinterovski View Post
    Or water meth fitted both which keep intake temps down,intercooler you can change if you have the money but on stage2+ it should still be ok on the standard i thought ?
    Phantom Black S3,Giac stg 1,Evoms intake,Lamin-x
    (to do list,update signature pic)
    Jan 2009
    125
    What difference does it make, in terms of power/reliability?
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,406
    Below Stg3,whilst you do get gains,they're nowhere near as large,but in hot weather,you certainly will notice that the car's performance doesn't drop off.
    I ran mine on the stock intercooler,without WMI until Stg3,and under most conditions,you probably wouldn't notice not having them,but under heavy acceleration on a hot day,it's very obvious.
    Reliability won't be affected without them.
    I change the plugs every 10 000 miles,or less if there are any misfires.
    Sep 2012
    85
    what would happen if you got it mapped to stage 2+ then got the ic fitted after? would it have to be mapped again or can you just bolt a bigger ic on?
    Jan 2009
    125
    Quote Originally Posted by S3Alex View Post
    I might get the plugs changed when it's in for stage 2+ as i think i'm getting occasional missfires at Stage 1. The engine light sometimes flashes for ten seconds when i'm near the limiter. Does that sound like a miss fire?
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,406
    Quote Originally Posted by Adamj View Post
    You can pretty much just get the IC fitted,as nothing else needs to be altered to accomadate it,but it is a sod to fit,and needs the front bumper assembly to be removed.
    Possibly,yes,but it's worth changing them at the same time as any upgrade like this in any case.
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,422
    ^^what alex said. he's a guy with the knowledge.
    but must add while additional or larger ic prevents from power drop on hot weather i've noticed that rolling in 3rd and higher gears there is a difference with ic. it keeps going harder/faster than without it.
    S3Alex and Kelza like this.
    Jan 2009
    125
    If i'm up upgrading to a Sachs clutch what flywheel and release bearing do i need?
    Jan 2009
    125
    Alex, whats the difference between the Sachs DMF and SMF? do these kits come with flywheel and release bearing?
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,406
    The DMF will soak up a lot of the engine vibrations and will feel smoother,whereas the SMF is lighter,and a lot harsher,especially at idle,where you will hear and feel more engine thrash.
    For high torque applications,the SMF setup is the only way,and for anything above 440lbs,you would need this,but below that you should manage on a DMF as I had with the Sachs organic.
    All the kits can be purchased in bits or as full kits,and you should replace the whole lot together ideally.
    david_phillips95's Avatar
    Nov 2008
    538
    I ran the Sachs clutch with the OEM LUK DMF and it was great, although mine did start slipping after just over a year of hard driving and a few 1/4 mile launches but that is to be expected. With the Sachs kit fitted and DMF you will notice a slightly heavier clutch pedal but it's well worth it for the performance gains.
    Jan 2009
    125
    Cheers guys.
    The cars going in on Monday for Revo Stage 2+, hope the clutch doesnt pack in on the dyno.
    coreythorny's Avatar
    Mar 2013
    Leicestershire
    425
    So which clutch are you going for then mate?
    Let us know how it holds up, I've been looking at the Loba kit but if the Sachs on the standard DMF is good enough then thats much less to spend!
    I never do launching starts and drive rather tenderly about. Only time i'd be using full stage 2+ power is overtaking from 3rd gear pulls.
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,406
    Quote Originally Posted by coreythorny View Post
    For what it's worth,I used the Sachs with DMF all the way to Stg3 before it eventually gave up at 440lbs.
    If you want total reliability I'd go for the Loba,but if you don't rag it,the Sachs/DMF will work.
    Mar 2013
    Leicestershire
    425
    Sounds a good shout, if not will make a decent get out of jail free cards for a while.
    I presume there's not even any point trying to get it mapped on the standard clutch as it will just slip on the dyno?
    Mar 2013
    Leicestershire
    425
    Also where can I find the Sach kit? Cant find anything on google, just the Helix kit from Backdraft
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,406
    Any decent tuner will know where to get a Sachs kit from.
    If they don't,then I would question why.
    Most cars are OK at Stg1 on the stock clutch,but most aren't on Stg2.
  28. #27
    wuta3's Avatar
    Jul 2012
    1,075
    Give Ben at Shark a ring. They sent me out a Sachs organic and DMF pronto at at a cracking price too.
  29. #28
    Kelza's Avatar
    MODERATOR
    Oct 2010
    Cumbria
    2,552
    Hi there give greame a call he will sort you out ..
    GNJ Motorsport
  30. #29
    Jan 2009
    125
    I've got no clutch ordered and it's going in for stage 2+ tomorrow, is there no way i'll get away with the standard clutch?
  31. #30
    Kelza's Avatar
    MODERATOR
    Oct 2010
    Cumbria
    2,552
    Hi gilberto i ran a standard clutch for a year on stge 2+ revo ,ok i was running 345 bhp and it lasted ,till i traded in for the rs3
  32. #31
    Kelza's Avatar
    MODERATOR
    Oct 2010
    Cumbria
    2,552
    But put a uprated clutch in and the power is a different story....
  33. #32
    Nov 2008
    538
    You can get away with the OEM clutch, my friend ran his like this and it lasted till he sold the car which was over a year but he never really drove the cad hard. As RS3-KEL said its a huge difference with a performance clutch, if I done it again I would run the OEM setup till it gave up then I would change it.
  34. #33
    Kelza's Avatar
    MODERATOR
    Oct 2010
    Cumbria
    2,552
    Funny thing is i bought a uprated dmf sachs from u david ,but i just wanted to get a rs3 so thats why i sold it on
  35. #34
    Nov 2008
    538
    Quote Originally Posted by RS3-KEL View Post
    Yeah I remember you took the lot off my hands, SACHS or an RS3...I know what I would have haha
  36. #35
    Mar 2013
    Leicestershire
    425
    keep us updated how it copes mate please.
    How many miles has your car done?
  37. #36
    Jan 2009
    125
    It's done 25,000 miles, I'll let you know how I get on.
  38. #37
    s3 th's Avatar
    Jul 2012
    59
    Mines still on the stock clutch. Went stage 2+ in april and its been fine, I drive it hard at times but never launch it. How long should it be expected to last?
  39. #38
    Jan 2009
    125
    Quote Originally Posted by s3 th View Post
    Is that with Revo? What power did you make?
  40. #39
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,406
    The average from virtually all of the companies is in the 360-370bhp region with HPFP,CAI and exhaust on the stock turbo.
    Thats about the maximum you can expect.
  41. #40
    s3 th's Avatar
    Jul 2012
    59
    I made 354 bhp and 367 ft/lb torque
  1. Replies: 8
    Last Post: 3rd May 2011, 06:40
  2. Meguiars 3 Stage...
    By amoffat in forum General Chat
    Last Post: 26th March 2003, 08:36
  3. It's all going horribly wrong!!!
    By Loretta in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th March 2003, 18:47
  4. Going up.... or not.....
    By Hopsta in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th February 2003, 16:40
