Sky InsuranceVolks Autos
Page 2 of 3 FirstFirst 123 LastLast
Results 41 to 80 of 85
Like Tree7Likes
Thread: Going Stage 2+
  1. #41
    Kelza's Avatar
    MODERATOR
    Oct 2010
    Cumbria
    2,457
    Heres one of mine
  3. #42
    Jan 2009
    124
    Car made 353 bhp and 289lbft, tuner said there was alot more torque to be made but didnt want to take any chances with the clutch. Feels rapid now!!
  4. #43
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,392
    RS3-KEL why do you have that power dip between 4500 and 5000 rpm's? is it clutch slip?
    i don't know what figures mine has but it feels quick :D
    s3 Ibis White ... Build Thread
    / Black Grill / FbMfSw / Sunroof / Hill Hold / Armrest / Black Leather-Alcantara interior / Rear Parking Sensors / Heated Seats / Folding Mirrors / Cruise / Rns-e mk2 // ttrs-Brembo Brakes / 12mm spacers / Forge Short + Side Shift / 42dd's / ITG CAI / GfB DV+ / Forge Catch Can / Milltek TBE / Forge Twin IC/ Autotech HpFp / H&R ARB's / WALK / KW v3's / RS4 fpr / Loba&Sachs clutch / Revo Stage 2+ / ...
  5. #44
    Jan 2009
    124
    Needed a new o ring on the fuel pump as the original one couldn't handle the increase in fuel pressure. Was a bit worried when fuel was leaking into the engine bay.
  6. #45
    Kelza's Avatar
    MODERATOR
    Oct 2010
    Cumbria
    2,457
    Hi S, its could have been as there was aways a dip , but tbh i should have stuck the sachs clutch in as i do miss that raw power ,from the s3 ,the rs3 is more calm through the dsg box ,no doubt a map will sort it out..
    S. likes this.
  7. #46
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,392
    that seems reasonable :D
    mine wasn't on rollers since stage2 since the stock clutch was giving up, but few days ago had a play with r8 v8 and i was surprised (not as much as the guy in r8) :D
    Kelza likes this.
  8. #47
    Kelza's Avatar
    MODERATOR
    Oct 2010
    Cumbria
    2,457
    Funny thing is when i put her back to standard she was a dream to drive ,and no loss of power ,felt really tight lol
  9. #48
    Jan 2009
    124
    Quote Originally Posted by RS3-KEL View Post
    Heres one of mine
    What was your Revo settings?
    S3 Revo Stage 2+
    Milltek Non Res-ITG-Autotech HPFP-Loba SMF
  10. #49
    Kelza's Avatar
    MODERATOR
    Oct 2010
    Cumbria
    2,457
    Hi will need to dig them out
  11. #50
    Jan 2009
    124
    I've just gone for the Loba/Sachs SMF set up, but noticed it comes with no release bearing, where can i get one?
    Will i need my map tweaked to run more torque or will the car automatically run more torque with the new clutch set up?
    Thanks again.
    James
    S3 Revo Stage 2+
  12. #51
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,392
    Quote Originally Posted by gilberto View Post
    Thanks again.
    James
    release bearing from audi. or maybe garage can source it for you.
    ideally, map would need tweaking. as it won't produce more torque without that.
  13. #52
    Jan 2009
    124
    Whats everyones Revo settings for Stage 2+ in terms of boost, timing and fuel?
    S3 Revo Stage 2+
  14. #53
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,392
    hey there,
    each car has different settings, for example my settings may not be good for your car, but it's an good starting point if you have nervs and time to do logging and tweaking.
    i have tried two: one set by revo which is b9t4f9, and another one b8t5f7.
  15. #54
    Jan 2009
    124
    Thanks for that, I'm on B7,T4 & F9. What setting would need changing to make better torque figures when the new clutch goes in?
    S3 Revo Stage 2+
  16. #55
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,392
    don't really know mate. i've had map update after new clutch so all has been done at the garage.
    you can play with the boost and fueling but with timming you need to be careful and log everything to check if it in the safe limits,
    i think it's best to ask garage.
  17. #56
    Jan 2009
    124
    Yeah I'll ask them to look at the map again when the clutch goes in.
    S3 Revo Stage 2+
  18. #57
    coreythorny's Avatar
    Mar 2013
    Leicestershire
    407
    Don't forget to bed the clutch in mate
  19. #58
    Jan 2009
    124
    Chaps, is there a difference between the Revo Stage 2 & 2+ software or is it dependant on boost, timing and fueling settings?
    S3 Revo Stage 2+
  20. #59
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    4,791
    Stg2+ software is fuel pump specific,i.e. it requires an uprated HPFP,and that,plus the software,fills out a lot of the dip in midrange torque that you otherwise get at Stg2.
  21. #60
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,392
    ^^ what he said :D
    S3Alex likes this.
  22. #61
    Jan 2009
    124
    Cheers, looks like Stage 2 went on the last time i was in for a tune but 2+ is going on tomorrow with the new clutch.
    S3 Revo Stage 2+
  23. #62
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    4,791
    As I said,you need the uprated HPFP for Stg2+,and it does make a difference,although it's the beginning of the slippery slope to really expensive mods.
    The car will take a few days worth of driving to adapt fully,but the increase in midrange torque is noticeable right away.
  24. #63
    Jan 2009
    124
    Quote Originally Posted by S3Alex View Post
    Yeah i've already got the HPFP fitted but i was told that they only put the stage 2 software on last time it was in for a map (when i also had ITG, Milltek and HPFP fitted at the same time)
    S3 Revo Stage 2+
  25. #64
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    4,791
    Then when you go back there's going to be a bigger grin on your face!
  26. #65
    Jan 2009
    124
    When fitting the new Rev D Diverter Valve, is it a case of just bolting in the new DV, do you have to worry about tweeking the map? will any fault codes be picked up after changing?
    S3 Revo Stage 2+
  27. #66
    RedDejavu's Avatar
    Feb 2011
    Bracknell
    1,332
    nobody mentioned that lower engine mounts would need changing to something stiffer:].
    Be patient. English is tough.
    Now:
    61 Audi S3 BE S-Tronic Ibis White: Build Thread.
    / Black Edition pack (SatNav, Bluetooth) / Parking Sensors / Tinted windows / piano inlays and finish / Cruise Control / Interior light pack /
    /Mods: REVO Stage 2+: Revo Intake / Milltek Resonated TBE / LOBA HPFP/ GFB DV+ / Crystal Clear H11 FOGS / Black roof + spoiler vinyl wrap / H&R Anti-roll bars / Superpro ALK /
  28. #67
    Jan 2009
    124
    Quote Originally Posted by RedDejavu View Post
    Does that make the cabin noise increase?
    S3 Revo Stage 2+
  29. #68
    RedDejavu's Avatar
    Feb 2011
    Bracknell
    1,332
    apparentley not if you choose road use version, track only version would have made all bit noiser as they are really harsh.
    Now:
  30. #69
    Jan 2009
    124
    So i've just managed to change my rev g diverter valve for the rev d. Easy job even for a complete novice!
    The rev g looks in surprisingly good condition. I'm still getting a flutter sound when accelerating hard in 3rd and 4th. Is this something to worry about or is it what's called compressor surge?
    Here's a few photos of the condition of the rev g:
    S3 Revo Stage 2+
  31. #70
    Reload's Avatar
    Bird is the Word!
    Jul 2010
    Midlands
    364
    I noticed the flutter sound when I replaced my old DV with a Rev D, absolutely nothing to be concerned about
    S3 8P2 Ice Silver, RNS-E, Bluetooth, iPod connection, Adaptive xenons, black styling pack, sunroof, privacy glass
    Mods since owned: Milltek Resonated TBE, Neuspeed P-Flo, Loba HPFP, Sachs Clutch with Loba SMF, Unicorn Motor Developments custom remap, brakes + suspension upgrades, LEDs internal and external, more interior kit
  32. #71
    XFi
    XFi's Avatar
    Jun 2010
    Grantham, Lincolnshire
    316
    Add XFi on Facebook Visit XFi's Youtube Channel
    My rev G was also in perfect condition but I changed it for piece of mind. Mine does this at stage one also.
    Audi S3 8P3 Stage 1
  33. #72
    Jan 2009
    124
    Quote Originally Posted by Reload View Post
    Do you get the flutter under hard acceleration and on gear change?
    S3 Revo Stage 2+
  34. #73
    XFi
    XFi's Avatar
    Jun 2010
    316
    I have compressor stall or fluttering but only between 3 & 4000 rpm. Also had it on my previous 8L S3 once I added an aftermarket intake. Compressor stall isn't a great thing for a turbo at all.
    Audi S3 8P3 Stage 1
  35. #74
    Jan 2009
    124
    Quote Originally Posted by XFi View Post
    Sounds similar. Good to hear i'm not the only one. cheers.
    S3 Revo Stage 2+
  36. #75
    Jan 2009
    124
    Here's some pictures of my Stage 2+ dyno results 355 bhp & 334 lbft.
    S3Alex likes this.
    S3 Revo Stage 2+
  37. #76
    Dean_T's Avatar
    May 2004
    West Mids
    511
    So how big is the smile on your face with the extra oomph now?
    Dean.
  38. #77
    Jan 2009
    124
    Yeah it's pretty rapid now. Just need to think about brakes and suspension now.
    S3 Revo Stage 2+
  39. #78
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    4,791
    kW v3 and either DaveB brakes,or AP/Brembo/RS brakes would fit the bill nicely.
  40. #79
    Jan 2009
    124
    I emailed Dave B but he never got back, ideally need a set up that fits over the standard wheel. Any ideas?? I'd prefer a drilled disk set up.
    S3 Revo Stage 2+
  41. #80
    RedDejavu's Avatar
    Feb 2011
    Bracknell
    1,332
    TTRS brakes are good
    Now:
  1. Replies: 8
    Last Post: 3rd May 2011, 06:40
  2. Meguiars 3 Stage...
    By amoffat in forum General Chat
    Last Post: 26th March 2003, 08:36
  3. It's all going horribly wrong!!!
    By Loretta in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th March 2003, 18:47
  4. Going up.... or not.....
    By Hopsta in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th February 2003, 16:40
