JMB RetrofitsEM Tuning
Thread: Bkd cam timing
    Apr 2013
    100
    Bkd cam timing
    Im still having issues with my a3 2.0tdi. In the morning/ when its been stood for a while and let cool down i start it, it missfires into life and puffs a cloud of bluey/white smoke that stinks of diesel then its okay! Had new turbo,glow plugs, glow plug loom. And a diffrent tandem pump. Still the same. Orderd my injector seals to try them. Im wondering if its my timing? From cold the injector readings are fine. The idle consumption goes upto 2.0l/h for a second or two thwn back down to 0.6-0.4 l/h. Is that normal? Also my torsion value is 0.0. Thanks
    tdi-man's Avatar
    Jul 2009
    1,611
    that use to happen to mine ended up being the head ;(
    would run fine just that it it chuff out smoke after a run and its left to cool for a while
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs /
    233 bhp - 309 ft lb - 419 nm (NEEDS A NEW MAP)
    Apr 2013
    100
    What happend to yours then?
    tdi-man's Avatar
    Jul 2009
    1,611
    would start and run fine once up to temp and parked up for a while would smoke for say 20 secs and clear and run fine .
    slight loss of water but not a lot.
    Apr 2013
    100
    I wouldnt say mine smokes for 20 seconds! Just one puff of smoke maybe 2-3 seconds and its fine! I havent noticed any coolant loss (touch wood) im thinking oil is seeping into the bore thry the injector seal and thats causing the smoke/missfire? Also its used from max to half way on te dipstik within 2-3 weeks! How did you diagnose your head?
    Apr 2013
    100
    Also my coolant temp sensor on vcds showed my car at 81 degrees when my gauge on the car was on 90! Could this be a fueling problem?
  1. BKD CAM TIMING
    By Rodney5950 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd May 2013, 22:44
  2. Help please - Fine tuned cam timing but I've screwed up! (TDI BKD)
    By ZeeSaffa in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th June 2012, 20:31
  3. Parts Required for Cam/Timing Belt Change - S3 2007
    By Boydie in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th July 2011, 22:57
  4. bkd cam shaft specs
    By tdi-man in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd February 2011, 16:32
  5. BKD engine timing belt change
    By sprout99 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th February 2009, 23:05
