Sky InsuranceBadger5
Results 1 to 25 of 25
Like Tree7Likes
  • 1 Post By NHN
  • 1 Post By essIII
  • 1 Post By Ads
  • 1 Post By NHN
  • 2 Post By wuta3
  • 1 Post By NHN
Thread: Bonnet won't release...!
    DJ-S3's Avatar
    Apr 2009
    Wakefield
    683
    Right, I've asked this somewhere before but I've asked about and no one knows how to get the bonnet open without the release mechanism in the drivers footwell. It's all connected down there but must go wrong under the bonnet.
    Does anyone know how to get under the bonnet without using the release? My panel beater friend is out of options and now is saying he'll have to break the grill to get it open!!
    Audi S3 8P 56plate.
    Any kind of info would be much appreciated. Like if there's a joining part to the wire under bonnet? Or if its a whole wire to the catch?
    Dom
    wuta3's Avatar
    Jul 2012
    Manchester/Sheffield
    1,059
    If you can get an idea of the mechanism, you might be able to use a thin strong bit of metal to trigger the release by going through the grill or a wheelarch or something? Slimjim/lockpick style?
    ​​Programmer/Web Developer, Headphone/Amp Geek
    06 SLine Special Edition Phantom Black 2.0T FSI Quattro A3
    Done: P-Flo, RevD, Sachs Organic, Milltek TBE + Res + Sports cat
    Wanted/Next:Intercooler, HPFP, Remap
    DJ-S3's Avatar
    Apr 2009
    Wakefield
    683
    Quote Originally Posted by wuta3 View Post
    Yeah, but as I can't get under the bonnet to see the mechanism it's a bit of a problem. Lol. Had the trim under the steering wheel off and pulled the bonnet release off and the wire is still intact. So something must of happened under the bonnet. Just can't get under to find out.
    I'm going to drive through to Audi in the morning and see what the technician says (probably bring it in and I'll look at it for 50quid an hour!!!) then ring around a few garages and see if they've had the same problem. I can't be the only one to have had this happen to them....
    27,089
    I'm little confused, but I'm almost sure I advised you about this already?
    The cable is in 2 parts, you need to reach up if possible to the right hand side & grab hold of the black cable, basically like a bicycle brake cable, may require a yank down & you may have to cut into it to get to the inner core, its a pita, if the cables come of the lock then its more than likely broken grill job.
    Ahhh that's right I said try removing the drivers side wheel arch liner to get in above there, as the cable goes round above the headlight & I know you can into that area as mine are of atm.
    martinivw likes this.
    autolatry's Avatar
    Jan 2013
    Yorkshire
    347
    I had this problem Audi said its the mechanism is designed so access can not be gained from inside....but if i took the car to them they would 'have a look'.
    I spent many hours under the car tying to get in, in the end I rang the RAC, he fiddled with the cable whilst I pushed down on the bonnet and it opened.
    Dec 2008
    278
    I got into mine by getting the car on a lift, removing the undertray, dropping out the fan and intercooler then triggering the catch with a screwdriver. Absolute ball ache, but grills are too expensive to smash!
    DJ-S3's Avatar
    Apr 2009
    Wakefield
    683
    You did Nigel but I can't seem to get to it that way and don't have the slightest idea of where or what it looks like to grab hold of it.
    Dropping the fan and intercooler would be alright but not sure how I would do that without removing the front bumper as the bumper goes under the car some 8inches...
    Dec 2008
    278
    Hmm, my bumper was definitely on. Was a 2008 8p2 s3.
    J8TT X's Avatar
    Jan 2011
    Leicester
    337
    I did this and it worked.
    Used Pliers to hold the black cable then another one to pull the cable inside while someone pushed down on the bonnet.
    Like above its quite hard and may take a couple of tries
    2005 Audi A3 2.0 TDI DSG S-line (8p1)
    Mods: 18" Gloss Black RS4's - 8p2 S-line Front Bumper - Black Grill - A5 LED Number Plate lights - LED Sidelights - Euro Style Plates - EGR Delete - RTech Custom Remap - Hot Start Issue Fix
    Pipeline: Lowering, Wheel Refurb, Coming Home Lights
    2007 VW Golf 2.0 GT TDI 140 (Wife's)
    Mods: 18" Charlestons
    DJ-S3's Avatar
    Apr 2009
    Wakefield
    683
    Ok thanks everyone. And I apologies again but when he said destroying my grill I panicked :/
    27,089
    Imagine the front lock carrier curves round the shape of the front of bonnet, the cable basically follows that same route, if you need a rough idea of area to get to the cable.
    Oct 2012
    139
    This is an ongoing problem with both Golfs and A3's. Keep the mechanism well lubricated! It really does make a difference. Doesn't stop all the failures but seems to stop most of them.
    DJ-S3's Avatar
    Apr 2009
    Wakefield
    683
    Spoke to Audi today and the quoted £112 vat and labour included for fitting a new cable. That's with not being able to get under the bonnet as I told them my problem. Going to give it a go myself again though before I give in.
    wuta3's Avatar
    Jul 2012
    1,059
    Quote Originally Posted by DJ-S3 View Post
    PPFFFTTTT. Id tell them to nob off. £122 quid.
    DJ-S3's Avatar
    Apr 2009
    Wakefield
    683
    £112*** ;-) but I know what you mean. If I can't do it myself though might have to.
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,223
    I'd pay them the £112 all day long. Or at least get a quote from an indie.
    Remove intercooler, pull this, press that, cut this, yank that. And then put it all back together again?
    Not me.
    I sense a "Bonnet won't stay shut...!" thread coming.
    DJ-S3's Avatar
    Apr 2009
    Wakefield
    683
    Quote Originally Posted by Ads View Post
    Not me.
    Hahahaha. I hope not....
    But that's what I was thinking. Try some other garages first and see what they say.
    wuta3's Avatar
    Jul 2012
    1,059
    Not me.
    Na coz they can use the VAG bonnet release tool then the special VAG fix bonnet release cable tool. They have it all planned out you see lol
    27,089
    £112 for no hassle, all day long, its a no brainer, just pay them & be done with it, pointless doing yourself tbh if they supply new parts & labour for that small cost, really is no brainer all day long.
    wuta3's Avatar
    Jul 2012
    1,059
    oh I thought it was £122 then (Audi) labour on top. My bad
    27,089
    Ads likes this.
    wuta3's Avatar
    Jul 2012
    1,059
    NHN and leeds2592 like this.
    27,089
    LMAO, brilliant photo lmao,, I wish your humour would be like a virus through this & other forums some days.
    wuta3 likes this.
    leeds2592's Avatar
    When I grow up, I want a 964!
    Apr 2012
    Leeds
    1,180
    Visit leeds2592's Instagram Channel
    This picture would have been a good call aswell...
    Anyway, Dom give Volks Works a call in Leeds for a price, I've taken my A3 there for alsorts doing. Might be a bit too far away though depending on where you are in Wakey.
    Black 2007 2.0 FSI Sport
    2011 Glossy Black RNS-E |AP Coilovers | 18" 7 Spoke OEM BE Alloy Wheels | H&R Trak+ Spacers 8mm (Front) 12mm (Rear) | MY11 Rear Lights | S Line Spoiler | Retrofitted MFSW | Retrofitted Cruise Control | Interior LED Light Pack | OEM LED Numberplate Bulbs
    27,089
    Looks like he's doing a shxt or stoned lmao
  1. URGENT HELP: Bonnet won't open, any other way? 8P S3
    By Boydie in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th March 2014, 17:05
  2. Bonnet won't open
    By ScottTDI in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th February 2012, 19:59
  3. Bonnet won't close, help please guys.
    By cossie in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st September 2010, 12:12
  4. F#@$!!! RNS-E Latch won't release...
    By VWAddict in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th January 2010, 21:51
  5. My bonnet won't open
    By voteforpedro in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th September 2009, 21:53
