AH FabricationsChris Nott
    Sep 2012
    Alarm/Siren Issues , Blown Fuse & VCDS Error
    Hi guys,
    i keep meeting my S3 with the hazard light on while it is parked locked.
    i get this a lot lately. seems the alam is setting off without a sound.
    i check with VAG COM and found these:
    4 Faults Found:
    01135 - Interior Monitoring Sensors
    004 - No Signal/Communication
    00323 - Vehicle Inclination Sensor (G384)
    01134 - Alarm Horn (H12)
    00849 - S-contact at Ignition/Starter Switch (D)
    008 - Implausible Signal - Intermittent
    went to check fuse number 17 (alarm fuse) which seemed to be blown. trying to replace it mad me blow another 2. seems there is an electrical problem but not sure if it is the alarm, siren or something else? where should i start looking?
    26,722
    Well it looks like you may have an ignition barrel problem, clear the faults & disconnect battery, replace fuses blown & reconnect battery & see which ones blow again, check all fuses then see which systems those fuses support & work back from there.
    Sep 2012
    thanks for the quick answer, i think you miss understood me:
    what i ment is while replacing fuse no. 17 the next one i put instead blow also, and the same for the 2nd time.
    fuse 17 is the alarm system according to the manual book. i dont know where to check from here, is it possible that a bad alarm horn can cause this short circuit?
  1. A6 Alarm Issues - Need help decoding VCDS Faults
    By Dan Harland in forum VCDS (formerly VAG-COM) forum
    Last Post: 30th May 2012, 12:48
  2. Power Loss issues (VCDS Error inside)
    By Nilz in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th March 2012, 12:38
  3. Alarm/siren concerns - VCDS
    By Naj in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th December 2011, 20:41
  4. Alarm siren help
    By matt116 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th August 2005, 13:04
  5. Alarm siren
    By LeeW in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd May 2005, 19:31
