EM TuningVolks Autos
Results 1 to 9 of 9
    dex140's Avatar
    Dec 2009
    190
    Rattling door handle
    Hi All,
    The painted metal cover for the door handle seem very loose and rattly on my A3..has anyone ever experienced this? Is there any way i can tighten it up? I have looked for fixings but cannot work it out!
    Thanks for the help!
    wangdoodle's Avatar
    Apr 2013
    34
    Yes mate.there is a thin stainless silver clip about 2 1/2" long that slides forward to release the handle and back to hold it in place.
    If you lift the handle up slightly you may be able to just make it out from the top.use something thin like a credit card to try and push it back toward the rear of the car.Drivers side is towards the rear to secure,I think passenger side is opposite way round.
    If you want to see how it works,slide the metal clip forward and take the handle off.
    Hth
    dex140's Avatar
    Dec 2009
    190
    Ah so if i find the clip and slide it towards the rear of the car it should tighten it up?
    wangdoodle's Avatar
    Apr 2013
    34
    That's it mate.I'll post a pic up when I get in later...
    wangdoodle's Avatar
    Apr 2013
    34
    Like this....
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,079
    I had this mate and I couldn't get it to stop rattling, no matter what i did I cut off a small piece of sponge and took the handle off carefully placed the sponge under the handle and using the method above with a credit card put it back on.. That was a year ago and it's tight on with no rattle
    A3 Sportback 2.0 TFSI S-Line Quattro Stage 1 Tune it up - Lowestoft Custom Remap- 6187 RPM developing 260 bhp 279lbs ft Akoya Silver, Roof rails, Black heated Vienna Leather, Bose upgrade, Bluetooth
    wangdoodle's Avatar
    Apr 2013
    34
    I suppose you could always use silicone sealant to secure the handle.a bit red neck but mightdo the job if you've tried all other routes.
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,079
    Quote Originally Posted by wangdoodle View Post
    The sponge is the best fix I've ever done just pushed the handle out a bit so it didn't rattle and it felt less loose than before and it's damage free :-)
    dex140's Avatar
    Dec 2009
    190
    Cheers fellas ill have a look at it this weekend! Its pi**ing me rit eoff though!
  1. Rattle from door handle, what are my options?
    By DJM1982 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 1st August 2013, 07:15
  2. door handle rattle
    By si hoc in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 27th June 2011, 16:29
  3. drivers side door handle cover rattle
    By felixtcat in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th June 2010, 10:07
  4. Program KEYFOB with door handle mod
    By imported_phink in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th July 2004, 16:28
  5. colour coded door handles
    By justin_1ss in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th April 2004, 08:04
