AH FabricationsBadger5
    Apr 2013
    EGR Valve Removal - Please Help Unable to Access
    Morning All,Sorry to post another on EGR valve removal but i have been searching all previous and i am un able to find anything, I have a 2007 TDI 170 Sportback and i am trying to remove the EGR Valve and Throttle Body to clean. However the exhaust inlet pipe comes in at different angle to pictures i have seen and this prevents me from being able to get to the rear bolts. Can anyone please help with an pictures or anything??Also on various occations the glow plug light comes on flashing, however the car does not go in to safe mode and when the car is switched off then on it resets itself. A minor issue maybe??I hope someone can help.Kind RegardsPaul
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    745
    You need a really long Allen drive, preferably on a flexible joint to get the bolt at the back that holds it to the manifold, & even then its still a mare to get to. The other 2 are a cinch.
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted... Still....
  1. EGR valve removal
    By Glyn E in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th July 2012, 19:57
  2. Sump Removal ...please help!
    By lucksta in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd June 2009, 12:53
  3. A3 8L Quattro gearbox removal please HELP
    By A3Quattro1985 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th February 2009, 18:27
  4. Air Filter Element Removal - Please help
    By Platinum70 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th May 2006, 21:58
