EM TuningVolks Autos
Results 1 to 7 of 7
    leeds2592's Avatar
    Apr 2012
    Leeds
    996
    Offside Wheel Trouble - Wheel Bearing?
    Hi all,
    Got in my car and started to drive yesterday and heard a constant RRR RRR RRR kind of noise. Only happens when car is moving and sound gets worse when I turn left. The noise is coming from the right hand side.
    A few months ago I had some work done on that side, new suspension arm and supposedly new wheel bearing. I jacked it up today and there is a lot of play in the wheel. When wiggling the wheel, the brake disc, driveshaft etc all move as well. Does this sound like the wheel bearing or something that may not have been tightened up right when the work was done?
    Got a video when I had it in the air of the wheel moving, can upload it if needed.
    Thanks in advance
    Black 2007 2.0 FSI Sport
    2011 Glossy Black RNS-E |AP Coilovers | 18" 7 Spoke OEM BE Alloy Wheels | H&R Trak+ Spacers 8mm (Front) 12mm (Rear) | MY11 Rear Lights | S Line Spoiler | Retrofitted MFSW | Retrofitted Cruise Control | Interior LED Light Pack | OEM LED Numberplate Bulbs
    leeds2592's Avatar
    Apr 2012
    Leeds
    996
    Anyone?
    Oct 2012
    Warrington, North West
    959
    I'd personally ring them up and get it back to them and explain its only happened since they worked on it
    leeds2592's Avatar
    Apr 2012
    Leeds
    996
    That's my job for later on today.
    Just wanted to get some sort of idea of what the most likely problem could be, although I do understand it could be one of a number of things.
    26,747
    Remove the wheel & see if the large center shaft bolt has come loose.
    leeds2592's Avatar
    Apr 2012
    Leeds
    996
    Its booked in with garage on Monday, but I'll have a check tomorrow morning.
    Easy to tighten if its loose?
    Aug 2003
    291
    i had similar sound after car was fitted with hew mechatronics, everyone thought i was imagining it but mpg was worse and even the wife noticed it,
    it was the front left wheel bearing, had it changed by brilliant local independent for €100 and all is ggod again.
    Given how the front left wheel gets the most abuse from ditches and potholes it made sense that it went.
  1. S-line suspension & wheels with wheel spacers
    By circleswim in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th July 2013, 18:55
  2. WHEELS R8V10 WHEELS OR BBS CK ??
    By adam1991-18 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st May 2012, 09:15
  3. Wheels. Nice Wheels.
    By I'mRonBurgundy? in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th June 2008, 18:47
  4. Front Wheel Liner/Wheel Spoiler
    By arthurfuxake in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th May 2006, 10:51
  5. Wheel these wheels fit the 1998 A4 SE?
    By manikm in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd May 2004, 18:49
