Sky InsuranceChris Nott
Like Tree1Likes
  • 1 Post By Lewis583
Thread: 2010 Audi S3 - Emission light on - misfire error code
    Apr 2012
    Aberdeen
    17
    My emission warning light illuminated on my dashboard a couple of days ago and is still on. A scan of the ECU shows two error codes 1. Random/Multiple cylinder misfire detected and 2. Cylinder 1 misfire detected. I'm assuming from that my problem is related to cylinder number 1.
    Tried replacing the spark plugs upon advice from mechanic but no change.
    Car is running fine except engine splutters (probably misfiring) when starting from cold for about a minute and then runs fine after that.
    Car made 279 BHP on dyno in standard tune with the emissions light on so she's not down on power.
    Any ideas what to try next? Mechanic who did the dyno run recommended new coil pack if the new spark plugs didn't cure the problem. I guess I could swap a couple of the coil packs around to see if the cylinder 1 misfire code comes back after I erase it. That would at least rule out the coil pack.
    Is cylinder 1 on the left or right when you are looking at the engine from the front of the car?
    Any advice or suggestions greatly appreciated! Cheers.
    Tay
    May 2012
    Warrington
    366
    Like you said, try new coil packs and spark plugs. It's best to replace coil packs in pairs and they are known to go one after the other in these pairings.
    Had a similar incident with mine, all new coil packs solved it.
    Lewis583's Avatar
    Mar 2010
    870
    Yes, Cylinder 1 is on the drivers side. Swap cylinder 1 coil pack with cylinder 2 and see if the fault follows. If it does then the coil pack is the obvious culprit
    RedDejavu likes this.
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    Apr 2012
    Aberdeen
    17
    Cheers lads, will try swapping the coil pack on cylinders 1 and 2 and see what happens.
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    Worcestershire
    2,786
    I had this problem exactly on my mrs clio. I replaced everything, plugs, coil.....still no good, I then tested the resistance on all the injectors....and one was reading rubbish. Replaced, problem solved.
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
  1. Emissions light on FSi
    By jodeci in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th April 2005, 21:21
  2. Audi A4 Oil Light - HELP HELP :(
    By slips in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th January 2005, 18:02
  3. Mechanic gives up on Emissions Light problem...
    By vpg_ii in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 5th January 2005, 16:00
  4. Emissions Light
    Last Post: 2nd January 2005, 23:08
