My emission warning light illuminated on my dashboard a couple of days ago and is still on. A scan of the ECU shows two error codes 1. Random/Multiple cylinder misfire detected and 2. Cylinder 1 misfire detected. I'm assuming from that my problem is related to cylinder number 1.
Tried replacing the spark plugs upon advice from mechanic but no change.
Car is running fine except engine splutters (probably misfiring) when starting from cold for about a minute and then runs fine after that.
Car made 279 BHP on dyno in standard tune with the emissions light on so she's not down on power.
Any ideas what to try next? Mechanic who did the dyno run recommended new coil pack if the new spark plugs didn't cure the problem. I guess I could swap a couple of the coil packs around to see if the cylinder 1 misfire code comes back after I erase it. That would at least rule out the coil pack.
Is cylinder 1 on the left or right when you are looking at the engine from the front of the car?
Any advice or suggestions greatly appreciated! Cheers.
