Sky InsuranceChris Nott
Results 1 to 9 of 9
    JPK
    May 2012
    278
    Creaking noise when accelerating right from standstill
    This existed when the car was stock and still exists.
    I have replaced engine/trans mounts, strut mounts & bearings, shocks, springs, tie rods, tie rod ends, ball joints, front/rear control arm bushes, sway bar end links, brakes and have tyrolsports deadset subframe kit.
    Any ideas? Doesn't seem like much else to replace other than axles/CVs and wheel bearings?
    2005 A3 2.0T DSG Oettinger Body Styling, 19" RS5 Reps, APR Stage 1, Forge Twintake, Remus catback, BSH PCV Fix, 034 Motorsport Mounts, WALK, Whiteline bushings (F&R), Whiteline RSB, Whiteline BSK, Whiteline adjustable end links, H&R Sport Cup Kit, Stoptech Drilled Rotors, Hawk Pads, Tyrolsport stainless lines, Tyrolsport Calliper bushings, Tyrolsport DeadSet Subframe kit.
    coreythorny's Avatar
    Mar 2013
    Leicestershire
    402
    Might sound daft, feel daft saying it, but have you checked the heat shields aren't touching the back of the disc or look like they might be a bit close?
    on my old car these used to cause me issues, slightly bent it back and was sorted. Probably not just a 2pence worth.
    JPK
    May 2012
    278
    Open to any suggestions. Will have a good look at that tomorrow. It's weird that it only does it when accelerating right from a standstill - coming out of a street and turning right.
    Doesnt do it when slowly turning in a carpark or turning at speed. Have tried the usual bad CV tests (reversing full lock etc), no issues there.
    Mar 2013
    Leicestershire
    402
    I believe a lipped disc can also cause a noise on lock but you say you've changed them so.
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    683
    Could be your steering rack itself, it's quite a common issue.
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted!
    Bits for sale...
    Genuine S-line 18" alloys, A3 Sportback rear lights. A3 5dr window switches & mirror switch. , Brand new PD170 engine cover. PM for details.
    JPK
    May 2012
    278
    Hope it isn't steering rack. It isn't really exhibiting usual symptoms for a faulty steering rack however.
    Jul 2009
    24
    Was this issue ever solved? I have something similar.
    Johnny Bravo's Avatar
    6+1 Gears
    Jun 2009
    Romania
    715
    I also have a knocking when turning left and back to straight position. Nothing when I turn right. In my case I think is the left hand side ARB bush. I came to this conclusion after removing the tie rods and turned the steering wheel again. There was no noise. Now I'm waiting for new H&R bushes to replace both of them and hopefully getting rid of that noise. After spending almost 7,000 euros on new suspension, ARBs, control arms, brakes etc. is very frustrating to have this problem...
    DSG | Vienna Leather | Bose Sound | MFSW | Interior Lights Pack | Light & Rain Sensors | Auto Dimming Mirror Mods: LED RNS-e | FL LED Tail Lights | Bi-Xenons | Illuminated Speaker Grilles | Tinted windows | Chrome Switches | Chrome Paddles&Commands | RS4 Start Button | Cruise Control | S3 Pedals | S3 Roof Spoiler | 18" BBS CH | H&R Spacers 10/15 mm | Bilstein B16 PSS10 | H&R 26/24 ARBs | TT Arms | S3 Front Brakes+DS2500+Tarox F2000 | HEL Brake Lines | VNT20 | EGR&Cooler Delete | Custom Remap
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    933
    Brakes binding?
    VCDS USER
  1. Whining noise when accelerating, any ideas?
    By Nuno_rules in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd August 2013, 04:52
  2. Clicking noise when turning right?
    By tedward in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th September 2012, 07:48
  3. Unusual Noise when accelerating????? HELP
    By Ports in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd December 2011, 12:16
  4. Funny noise when turning right
    By jamesbeacroft in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 16th November 2009, 21:25
  5. Noise when turning right
    By daverob in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st August 2005, 22:40
