Volks AutosMonster Motorsport
Results 1 to 16 of 16
    Jonse's Avatar
    Oct 2012
    353
    New wheels - what tyres should i get.
    Hi Guys
    just picked up my new wheels today BBS CH
    [/URL]
    They are staggered with 8J front and 9J rears. Im currently running on standard suspension but with the plan to go to HR lower springs next year.
    What tyres do you recommend? The company suggest 225/40/18 all round.
    I was thinking 225/40/18 on the front and 245/35/40 on the back.
    Any advice would be great
    Ryan
    Persian's Avatar
    CEO
    Sep 2012
    186
    225/40 is perfect on 8J but on the rear I think 245 would have clearance issues considering they are 9J! I guess back needs to be down on 225 also.
    Nov 2011
    57
    I would also suggest 225 due to clearance problems.
    What offsets are the wheels?
    I was looking at the BBS vz but was concerned about clearance issues as they are 8j et 44 and my S3 is lowered about 25mm and I don't really want any rubbing!
    Jonse's Avatar
    Oct 2012
    353
    the ET is front 8J ET45 backs 9J ET42. So we saying 225.?
    Would that be alot of stretch, i dont want to lose that much grip.
    Nov 2011
    57
    They would be stretched but if you fit anything bigger you will get quite bad rubbing.
    I think I will get rubbing with 8j et44 and yours will sit another 14mm further out!
    Jonse's Avatar
    Oct 2012
    353
    Wow how do you work out how much further it sits out then standard.
    Dont know alot about ET.
    Persian's Avatar
    CEO
    Sep 2012
    186
    Quote Originally Posted by Jonse View Post
    Here you go mate
    http://www.1010tires.com/Tools/Wheel-Offset-Calculator
    Just plug in standard wheel width and ET (7.5J ET54) and your preferred or new wheel size and it will work out it out for you.
    ET is just about how much further the wheel sits from the hub to the arch in other words A3's standard is ET54 and the maximum which most go for is ET45+. I Personally am on 8J ET43 with 225/40.
    Hope I ain't off topic and helped
    Jonse's Avatar
    Oct 2012
    353
    Wow im not sure if i know how to use it but it shows my rear wheels will stick out my 31mm thats sounds like it will stick out loads i was hoping for flush
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    4,791
    245s on the rear is doable but you'll need a fair amount of camber to avoid rubbing.
    At the front it's a different matter and we had a serious amount of work getting 245s under there.
    Jonse's Avatar
    Oct 2012
    353
    oh ok. Im looking to get some tyres today. Is it best to go for 225 all round then? or 225 on the rear and 215 on the front?
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    4,791
    Its best to have the same tyre size all round.
    225s should fit under the arches as mine was on 225x40x18s from stock but that assumes the offset of your rims is correct.
    I know nothing about offsets but I do know that with everything very carefully worked out on mine that we had to go to adjustable topmounts to get sufficient front camber to get the 245s fitted.
    Not a cheap option.
    coreythorny's Avatar
    Mar 2013
    Leicestershire
    405
    Quote Originally Posted by S3Alex View Post
    Not a cheap option.
    This, not forgetting if you run Quattro you need to ensure rolling diameter is within a stupidly fine tolerance.
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    4,791
    Quote Originally Posted by coreythorny View Post
    Absolutely.
    Like all things Quattro and then check camber etc regularly.
    Feb 2009
    Aberdeen
    2,490
    Quote Originally Posted by AdriansS3 View Post
    You won't. I had 8.5" wide 19s at ET 44 with 225/35 and no rubbing.
    Hunt is over
    1st Audi - 2001 Ming Blue 8L S3 210
    2nd Audi - 2008 Black 8P2 S3 3dr
    and now - 2007 Daytona Grey B7 RS4 saloon
    Jun 2011
    249
    225/35 will be fine, I'm on eibach sportline springs and running front and rear on 9J's front is 215/35 with spacer to give clearance, and rears on 225/35
    A3 S Line 2.0 TDI Sportback - DSG
    BOSE, cruise control, bi-xenons, MFSW, Heated seats, paddle shifts, ipod connection
    19" Speedlines | Reverse camera | Eibach Sportline Springs | MY09 LED Tails | Eibach Spacers Front 10MM Rear 12MM | Pioneer HU | Private Plate | Tints | LED numberplate | Interior Light Kit
    Nov 2012
    Belfast
    23
    Lovely wheels mate.....I agree with everyone and reckon a 225/40 will work perfectly on them.
    Could you do me favour though.....post some pics up of the 9j rears please.
    Thinking of buying some CH's later this year and I want to see how much concave there is on them.
    Noodle's '06 A3 Sportback 2.0 T - Neuspeed P-Flo Intake, Milltek Cat Back Exhaust, Revision D Valve, Revo Stage 1 Map, TTS Engine Cover, BC Racing Coilovers with Camber Adjustable Top Mounts, 18" BBS CK ii Air 2 Piece Splits, US Number Plate Delete. More to come......
  1. Just ordered new wheels need tyre advice
    By Autograph Baz in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th January 2009, 16:46
  2. Pics Of New Wheels! What Do You Think?
    By dkingy11 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th July 2008, 18:42
  3. Clutch fitting - What spares should I get before hand?
    By Soupie69uk in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th January 2008, 18:21
  4. What tyres should i use, how big can i go?
    By in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th June 2005, 16:00
  5. What chip should I get?
    By Crippsy in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th January 2005, 19:29
