    Oct 2012
    57
    audi a3 loss pickup
    Hi,
    i have an audi a3 2009 1.9tdi, car has been running fine but recently i have noticed that the pickup has been reduced specially in gear 1 and 2.
    before i used to be able to zoom off at traffic lights but now it seems the rev counter goes up but the car just does not move.
    i taken to a garage who checked errors and none were found, please can someone advise what the issue can be.
    thanks
    d
    26,777
    Manual, maybe slipping clutch if revs raise & limited movement.
    Oct 2012
    57
    hi,
    is there any way i can test the clutch without taking to garage? as in put car into 2nd gear and see if moves etc like you would with a petrol?
    thanks
    d
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    934
    Driving uphill in 4th or 5th gear around 2000 revs, try to accelerate hard and observe whether the rev counter matches acceleration. If not then your clutch is buggered.
    VCDS USER
    Oct 2012
    57
    Ok just tested clutch....put in gear 3 and tried to move very slowly and car stalled.
    Gear 3, 2000 revs put clutch down and revs when down and put clutch up revs when back up.
    Seems like the clutch is fine....any other ideas?
    D
  1. Audi almost losses control!
    By Dazmo in forum General Chat
    Last Post: 30th August 2011, 22:28
  2. Audi A4 loss of of power, turbo?
    By mattsavage in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th November 2007, 16:56
  3. Audi A6 Avant 1.9tdi 130pd loss of power
    By barney in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 31st January 2007, 15:20
  4. Audi 80 1.9 TDi - intermittent loss of power
    By horlix in forum Diesel forum
    Last Post: 2nd May 2006, 22:07
  5. audi 80 tdi 93 intermittent power loss
    By asda in forum Diesel forum
    Last Post: 3rd March 2006, 14:48
