Results 1 to 18 of 18
Like Tree1Likes
  • 1 Post By NHN
Thread: Went for boost leak test and found this bad boy ! Pic inside
    TDI140's Avatar
    May 2011
    1,293
    Nice big split in the hose that is on the outlet of the turbo housing, fitted hose and car made 225bhp and 341ft lb
    A3 2.0TDI FWD sportback with GT1756 225bhp 351ft lb, forge boost hoses red, milltek decat system, BMC panel filter, golf gti edition 30 full front brakes brembo pads, black honeycomb grill, full oem s line kit + cupra r lip, LED side lights, OEM xenons, LED interior lighting, LED A8 number plate lights, boost gauge, alloy catch can with red hoses, FBSW, windows tinted, de-badged, now on air ride with chassis notch
    26,776
    So I guess Forge wasn't at fault then :P
    TDI140 likes this.
    Mar 2010
    154
    Oct 2012
    29
    Wow. :o
    Random question - What sorta 0-60 you getting with your setup? That torque is amazing!
    |62 Plate - Audi A3 2.0 TDI 170 Black Edition| - |Glacier White| - |Comfort Pack| - |Interior Light Pack|
    |Light and Rain Sensor Pack| - |USB Console| - |Audi Exclusive Line Pack|
    Johnny Bravo's Avatar
    6+1 Gears
    Jun 2009
    Romania
    730
    I've changed that hose on my car two weeks ago too.
    In my case though that wasn't the source of the hissing noise. It was the pipe between the turbo and EGR cooler.
    DSG | Vienna Leather | Bose Sound | MFSW | Interior Lights Pack | Light & Rain Sensors | Auto Dimming Mirror Mods: LED RNS-e | FL LED Tail Lights | Bi-Xenons | Illuminated Speaker Grilles | Tinted windows | Chrome Switches | Chrome Paddles&Commands | RS4 Start Button | Cruise Control | S3 Pedals | S3 Roof Spoiler | 18" BBS CH | H&R Spacers 10/15 mm | Bilstein B16 PSS10 | H&R 26/24 ARBs | TT Arms | S3 Front Brakes+DS2500+Tarox F2000 | HEL Brake Lines | VNT20 | EGR&Cooler Delete | Custom Remap
    Apr 2011
    63
    is it possible to have boost leak without limp mode?What are the symptoms?
    26,776
    Yes, depends on the severity of the leak though, if its extreme then of course limp occurs, but minor it may just seem a little of key as such as its based the fuel levels on the air intake which it isn't receiving due to the leak, ideally it needs leak testing to be sure.
    TDI140's Avatar
    May 2011
    1,293
    Thanks NHN i feel stupid now lol although Forge coupler was also leaking a little but was mainly that i appologise to forge lol, ive loads of couplers and will fit forge hose back on, also dyno'd again and got increase from 217bhp 341ft lb to 225bhp 341ft lb
    8bhp increase but no more torque, every bhp increase is a happy moment :-D
    TDI140's Avatar
    May 2011
    1,293
    Quote Originally Posted by articuno88 View Post
    Wow. :o
    not sure 0-60 peak torque is at 2300rpm ao clutch survives also only smokes after peak torque kicks in im happy with resukt at the moment
    TDI140's Avatar
    May 2011
    1,293
    Quote Originally Posted by jimpa10 View Post
    the pipe that had split on mine in the first post i had no lights on the dash but boost gauge would not show more than 5psi so wasn't holding boost at all then was smoking a lot under acceleration also jerking a lot nearly un drivable
    Apr 2011
    63
    Quote Originally Posted by TDI140 View Post
    Now did it stop smoking?
    TDI140's Avatar
    May 2011
    1,293
    Smokes still but thats due to remap over fueling but i have oil sitting in exhaust from turbo blowing up so it smoke more than usual but then again its a TDI so im ok with it lol
    26,776
    Clean out exhaust, I used a cleaner from a agricultural company in Italy & cleaned it all out perfectly & no cat issues, smoking lasted seconds due to cleaning the whole lot out, never did it since.
    TDI140's Avatar
    May 2011
    1,293
    I have to cat so no prob there, will clean it out at some point as it comes off in pieces as its milltek
    Jun 2013
    Hi guys
    same issue i have with some oil in the xhaust due to a blownnturbo...all is fixed now, though i'm experiencing a serious loss of power n boost (replaced boost pipenthat a leak) so am thinking maybe its a faulty EGR...am i thinking in the right direction?
    TDI140's Avatar
    May 2011
    1,293
    Quote Originally Posted by smurf_rider View Post
    Hi guys
    In what way is car down on power ? If its not picking up very well then it sounds like boost leak so u need to test the boost hoses with smoke machine also if its making a dump valve kind off noise its definately boost leak, oil will take a good 6mo ths to clear out or can be cleaned out with cleaner as mentioned above in a previous comment also you shpuld make sure all hoses are inserted into pipes properly as could be leaking from there aswel
    Jun 2013
    its not as quick n responsive as before, especially when it shifts into4th, 5th n 6th gears and when i put foot down so it change dwn to a lower gear (dsg) ....uphills are battle now, n that shudnt be when u driving a tdi a week ago audi dealer changed a boost pipe coz it had a leak and a flap motor /throttle body....thnx for ur feedback, think i'll check for boost hoses leak again....
    TDI140's Avatar
    May 2011
    1,293
    Egr pipe under the IMF at front of engie. Might not be sutting flush with IMF housing
  1. any reason why this wouldnt work? boost leak test
    By karl210 in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th September 2012, 15:30
  2. Testing for boost leaks
    By LiveWire in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th July 2011, 08:14
  3. Pressure test kit for boost leaks??
    By AudiiduA in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th March 2011, 20:27
  4. Test for boost leaks
    By 1animal1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st October 2008, 12:20
