Monster MotorsportBadger5
    Apr 2013
    100
    Anybody help me? Bkd starting problem.
    I have a audi a3 2.0tdi bkd engine. Had a new turbo, cambelt kit and waterpump. Used diesel purge to clean injectors. When leaving the car over night or for a long period of time when i start it sometimes it misses a couple of times and a puff or white/blue smoke comes out the exhaust that stinks of diesel! Any ideas on what this could be? Thanks
    27,009
    Yeah, who did the cambelt, did they look of the cams, could be of by a tooth etc, mine was of by a fair bit on both & caused me no end of issues.
    Apr 2013
    100
    Well me and my mate whos a mechanic and me a training mechanic did it! We used the lolypop tools and i ajusted the cams on vcds. I noticed from cold the consumption shoots up to 2.0 l/h then after a couple of seconds goes back to 0.6-0.4 l/h!
    27,009
    Well they should be ok then if using correct pinning tools, like these:
    http://www.lasertools.co.uk/items/pd...structions.pdf
    Apr 2013
    100
    Thats the ones we used! Should the consumption go upto 2.0 l/h on a cold start?
  1. Car Starting problems - Help please
    By max10 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 29th November 2007, 10:05
  2. S3 Starting Problems ???? I Need Help !!!!
    By jamieface in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th November 2007, 12:59
  3. 1998 S4 warm starting problem? HELP!
    By myfirsts4 in forum General Technical / How To
    Last Post: 15th July 2007, 11:19
  4. Starting problems on 98 A4 1.8t need help
    By audia4t99 in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th August 2004, 00:25
  5. HELP (STARTING PROBLEMS)!!!!
    By harps21k in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th June 2004, 20:13
